Re: asta e motor Vtec sau nu?
D16Z6
VTEC
Found in
1992–1995 Honda Civic Si
1992–1995 Honda Civic EX, EX-V
1992–1995 Honda Civic ESi (European Market)
1993–1995 Honda Del Sol Si (US)
1993–1996 Honda Del Sol ESi (European)
Bore and Stroke: see D16 Series Engines
Displacement: see D16 Series Engines
Rod Length: 137 mm
Rod Ratio: 1.52~
Compression: 9.2:1
Power: 125 bhp (92 kW, 125 PS) at 6,600 rpm
Torque: 106 lb·ft (14.7 kg/m, 144 Nm) at 5,200 rpm
Volumetric Efficiency: 87.68%
Redline: 7,200 rpm
Fuel cut: 7,411 rpm
VTEC switchover: 4,800 rpm
Fuel control: OBD-1 PGM-FI
Head code: P08
ECU code: P28
conform wikipedia.
pe scurt, e vtec și la noi în principiu îl găsești mai des pe crx del sol.
GO STRONG!
GO PROUD!
GO ON!
GO HARD OR GO HOME!
