Daca nu ai probleme cu banii .. iti recomand cu toata inima mea un BMW M5 2004-2005 V10 507PS
Type: V10
Displacement cu in (cc): 301 (4941)
Power bhp (kW) at RPM: 500(373) / 7750
Torque lb-ft (Nm) at RPM: 383(520) / 6100
Redline at RPM: 8250
Brakes & Tires
Brakes F/R: ABS, vented disc/vented disc
Tires F-R: 255/40 ZR19 - 285/35 ZR19
Driveline: Rear Wheel Drive
Exterior Dimensions & Weight
Length × Width × Height in: 191.1 × 72.7 × 75.8
Weight lb (kg): 4012 (1821)
Performance
Acceleration 0-62 mph s: 4.5
Top Speed mph (km/h): 155 (250) - electronically limited
Fuel Economy EPA city/highway mpg (l/100 km): 12/18 (n.a.)
Base Price: 2006 BMW M5 - $81,200 / 86,200 € (last update: 10/10/2005)
The BMW M5 still makes its position as the benchmark, even after three generations, more the 35,000 sales and countless attempts by competitors to emulate its performance and success. Each successive generation has extended the bounds of both performance and luxury. The last generation M5, the most successful ever, significantly pushed the performance envelope with the first V8 from BMW M, mated to a six-speed transmission.
The all-new fourth generation BMW M5 pushes that envelope even further with the first V10 engine to power a production sedan. The new V10 produces 507 horsepower and 383 lb-ft of torque by European measure. This new engine is mated to a seven-speed SMG transmission. With this new powertrain the M5 offers the best power-to-weight ratio in its class. In the tradition of BMW M, the chassis has been engineered to keep up with the power while the exterior treatment is subtle, yet distinctive.
Sursa :
http://www.rsportscars.com/eng/cars/bmw_m5.asp
