16-02-09, 20:16
#121
Honda Driver
Member of: [Honda]
Re: putin ajutor va rog
Bem ce vrei tu, si whisky, numa da-mi un cod ca e nashpa pe liniste.
17-02-09, 16:15
#122
Member of: [Moderators] [Design Team] [Virtual Tuning] [BMW]
Snap7 nu ai gasit pe acolo ceva de marimea unui card de credit pe care sa scrie tot ce tine de masina, serii.... asa aveam la Corsa.
17-02-09, 16:20
#123
Honda Driver
Member of: [Honda]
Nu, n-am gasit. Mi-a zis si un amic de la o reprezentanta Honda sa ma uit dupa asa ceva dar nu exista. Astept acum un raspuns de la Honda Inidan. Sper sa fie cu noroc..
Dura lex, sed lex!
24-02-09, 17:51
#124
Member of: [Opel]
vezi ca ti-am dat add pe mess
poate rezolvam problema cu codul
24-02-09, 18:03
#125
Honda Driver
Member of: [Honda]
Vezi ca am ID-ul schimbat. Ti-am dat eu add pe cel nou.
29-03-09, 13:52
#126
Stie cineva cum se leaga un turometru? Help plssssss
29-03-09, 22:09
#127
Honda Driver
Member of: [Honda]
Uite un link care poate te ajuta: https://www.youtube.com/watch?v=IY_rLch-ggA
.. si trei fragmente luate de pe yahoo answers:
"Very simple. 3 wires one to ground, one to the wire from the coil that goes to the distributor and one to power the light for night driving."
"all i know that the black wire should be connected to ground. and the red one to power. batt...? but the other two i dont know"
"One of the two remaining wires is probably for the light inside. The other wire probably goes to the negative side of the ignition coil. To find the ignition coil simply follow the center high tension wire from the distributor cap."
30-03-09, 11:09
#128
Wow , tot complica mi se pare si parca nu m-as apuca de capul meu sa-l montez
30-03-09, 12:03
#129
Parca era un seicento alb pe forum la MAsina mea Fiat care si-a montat turometrul
30-03-09, 13:37
#130
AfterDark Racing Member
Member of: [AfterDark Racing] [FORD] [DACIA] [4Tuning International]
Este si un Ka, care are montat un turometru pe FORD KA
30-03-09, 15:18
#131
Va trebui sa gasesc un electrician meserias
30-03-09, 21:10
#132
Dacia Driver
Member of: [DACIA]
si eu vreau pe dacie ,cat ai dat pe el
31-03-09, 09:15
#133
1mil jumate, de la Cridem Oradea. Daca dai Cridem de google o sa te duca la ei direct. E un site bun si au o gramada de jucarele de tuning si tot ce comanzi iti trimit prin posta
Sa-ti iei mai repede sa mergem sa le montam
BMW POWER
31-03-09, 11:27
#134
Member of: [DACIA]
Mah! tu doar sa gasesti locul unde-l pui pe bord, ca vin eu sa ti-l leg, ca doar nu-i spuma chimica  Daca nu are schema de conectare ne putem da seama cu ajutorul unui multimetru ce rol are fiecare fir
31-03-09, 11:45
#135
 pai am si schema
