Go Back   Forum 4Tuning > Masini & Tuning > Discutii generale masini > Generalitati tuning
Generalitati tuning Tuning, Sfaturi utile, Trend-uri, Noutati, Discutii, Generalitati
Old 19-03-08, 14:13   #1
gioane10
Default kit turbo ford focus
salut am si eu un ford focus turnier cu motor de 1.8 116 benzina cp si as vrea sa-i pun turbina.m-ar interesa cat costa kitt-ul.
gioane10 is offline   Reply With Quote
Old 19-03-08, 14:25   #2
elspa
elspa's Avatar
Default Re: kitt turbo ford focus
daca e ztec motor iti pot aduce kitul complet cu 1250 euro
elspa is offline   Reply With Quote
Old 19-03-08, 19:35   #3
NWZeu
NWZeu's Avatar
[AfterDark Racing]
Este un Mk1 Zetec-E ...
Acum vin eu cu niste intrebari: de cine este fabricat kitul, ce stage este (cu sau fara FMI, la ce presiune merge si ce turbina este folosita).... de cine este stand-aloneul fabricat?
La pretul asta chiar m-ai facut curios
NWZeu is offline   Reply With Quote
Old 19-03-08, 20:36   #4
elspa
elspa's Avatar
SPA turbo
-T3 STAINLESS turbo manifold 00-03 FORD FOCUS ZETEC MOTOR
-godspeed TYPE-L INTERCOOLER (20X9X2.75" CORE SIZE)
-t3/t4 internal wastegate turbo
-bzs blow off valve
-fuel pressure regulator
-oil line, oil return lines & fittings
-universal 2.5" aluminum intercooler piping with silicone
CUSTOMER IS REQUIRE TO CUSTOM MAKE THE DOWN PIPE
TURBO SPEC:
INLET 2"
OUTLET 3"
BEARING TYPE WET FLOAT BEARINGS
OIL INLET 1/8 NPT
MAX PSI CAPACITY 27PSI
COMPRESSOR .48 AR COMPRESSOR
TURBINE .60 AR TURBINE
FLANGE TYPE T3 FLANGE
DOWN PIPE FLANGE TYPE 2.5" V BAND
MAX HP 350HP
am gresit eu, pretul este de 1450 euro, sorry
ID:	488411   Click image for larger version
ID:	488412   Click image for larger version
ID:	488414   Click image for larger version
ID:	488415   Click image for larger version
Sablare si PowderCoating - reconditionari jante, etrieri, etc
Da-ne un like pe Facebook
https://srzpowdercoating.ro
https://www.facebook.com/SRZPowdercoatingCustoms
Old 27-03-08, 22:22   #5
itzi177
salut am si eu un ford focus 1.6 16v Ti-vct 116 cp din 2006. cat ma costa un kitt turbo (daca se poate pune la modelul meu) si la cati cp ajung? MERCI!
itzi177 is offline   Reply With Quote
Old 28-03-08, 07:43   #6
elspa
elspa's Avatar
doar pentru 1.8 si 2.0 atat
Old 29-03-08, 14:23   #7
CJ-01-WOB
Observator 4tuning
CJ-01-WOB's Avatar
[Nissan]
[Mitsubishi]
[Toyota]
gasesti KIT TURBO pe ebay
preturile incep de pe la 500 GBP si merg pana la 2000 GPB ( pounds)
+ delivery
este lume care contra unui comision poate comanda .
mai urmeaza pe urma costurile de montaj
m-i se pare ca pt motoarele de 2 L poate impinge un maxim 350 cai .
Fresh Touring Origination
CJ-01-WOB is offline   Reply With Quote
Old 08-04-08, 17:33   #8
itzi177
am gasit turbina electrica pt ford focus 1.6 16v Ti-VCT 116 cp si vanzatorul mi-a spus ca mai castig 15-20 cp. poate sa-mi dea atata putere o turbina electrica?
Old 09-04-08, 01:56   #9
CJ-01-WOB
Observator 4tuning
CJ-01-WOB's Avatar
[Nissan]
[Mitsubishi]
[Toyota]
Nu
Old 09-04-08, 12:14   #10
itzi177
deci era o turbina electrica cu tot cu filtru de aer sport la 220 euro! dar banuiesc ca raspunsul e tot nu! aveti idee cam cati cp poate sa-mi dea chestia asta?
Old 09-04-08, 18:32   #11
CJ-01-WOB
Observator 4tuning
CJ-01-WOB's Avatar
[Nissan]
[Mitsubishi]
[Toyota]
sper ca nu iti imaginezi ca turbo pe o masina inseamna doar magaoaia aia in forma de melc care o pui sus in 5 minute , face pssssssss cand schimbi viteza si aduce cati-va zeci de cai bijuteriei tale cum multi viseaza.si pe langa asta si chip-ul minune care odata pus aduze zeci de cai (multi nu stiu ca aceste chipuri nu sunt compatibile pt toate masinile, si mai ales cand aud cat costa pt a fi montate profesional ,dau bir cu fugitii)
vrei mai multi CP ?
incepe prin un FULL EXHAUST SISTEM profi.
pe urma acorda-i masinii un sistem prin care sa respire calumea, nu filtre de aer luate de la piata.
si dupa ce vezi cat te costa toate astea incepi sa te gandesti daca iti merita sa bagii sute/mii euro intr-o masina pt a acumula cativa cai .
vrei o masina puternica ? cumpara una de la bun inceput.
chestiile care le-am zis sunt generale
nu le luati personal
Old 10-04-08, 00:11   #12
itzi177
Default Re: kit turbo ford focus
merci mult pt sfat! o sa ma gandesc bine inainte sa fac urmatorul pas.
Old 13-07-09, 09:45   #13
Popescu Ionel
Popescu Ionel's Avatar
o intrebare am si eu,daca modific motorul de 1.6 l (schimbare axa cu came,serpisori,etc.+ pistoane forjate) merge turbo pe respectivul motor zetec 1.6 l??
Popescu Ionel is offline   Reply With Quote
Old 07-10-15, 12:54   #14
nicujadu
Smile Re: kit turbo ford focus
buna am un ford focus mk1 zetec 16 16v 2002
se poate pune turbo pe el si cat ar costa un kit complect
multumesc anticipat
nicujadu is offline   Reply With Quote
