Go Back   Forum 4Tuning > Car-Audio, Multimedia & GPS > GPS - Navigatie - Multimedia - Comunicatii - Auto Gadgets
Old 26-11-07, 08:19   #1
GGI78
GGI78's Avatar
Default Alarma pe Logan
Ce parere aveti de:
AutoPage RF-315
SECURITY FEATURES
Two, 5 button Mini remote transmitters
Dedicated lock / unlock
56 bit random code hopping
Over 75 trillion codes
Anti-code grabbing
Code learning / anti-scan
Two car operational
Dedicated remote panic button
Parking light flash (dual polarity)
Dual stage shock sensor
Dedicated Horn output
Passive Arming & Auto rearm by-pass from transmitter
Pre-warning indicator Valet / override push switch
Starter Disable (relay & socket including)
5 stage super bright LED
Error by-pass reporting
Positive (+) and negative (-) trigger inputs
Dual polarity (+/-) keyless entry option **
Optional 2 Step unlock
Car locator function
True last door arming
Back-up memory system
Second channel auxiliary output
3rd channel auxiliary
115 db electronic siren
CONVENIENCE FEATURES
Multiple vehicle operation
Dome light illuminated entry
Window comfort lock feature
Passive / manual arming
Valet / override
Panic function
Trunk / hatch release output
Dedicated trunk trigger input
Lock / unlock outputs
Lock / unlock in valet mode
Remote chirp delete
Siren or Horn output
Pager output
2nd channel trunk trigger and shock by-pass
Limited lifetime warranty
PROGRAMMABLE FEATURES
Chirp delete
Manual / Passive arming
Passive arming door locks
Ignition control door locks
Chanel 2 pulsed / momentary
3rd Channel momentary / latched
Lock confirmation on/off
Automatic re-arm
Single / Double pulse locks
Pathway illumination
Arm voltage sense timer
Siren / Horn output
2 step Unlock
Door lock pulse timer
GGI78 is offline   Reply With Quote
Old 02-12-07, 09:25   #2
chitzi
chitzi's Avatar
Default Re: Alarma pe Logan
marfa:d
eu am una `maat`
chitzi is offline   Reply With Quote
Old 14-01-08, 21:48   #3
dukone
dukone's Avatar
imi poti spune la ce pret cu tot cu montaj? ms
dukone is offline   Reply With Quote
