Alarma pe Logan
Ce parere aveti de:
AutoPage RF-315 SECURITY FEATURES Two, 5 button Mini remote transmitters Dedicated lock / unlock 56 bit random code hopping Over 75 trillion codes Anti-code grabbing Code learning / anti-scan Two car operational Dedicated remote panic button Parking light flash (dual polarity) Dual stage shock sensor Dedicated Horn output Passive Arming & Auto rearm by-pass from transmitter Pre-warning indicator Valet / override push switch Starter Disable (relay & socket including) 5 stage super bright LED Error by-pass reporting Positive (+) and negative (-) trigger inputs Dual polarity (+/-) keyless entry option ** Optional 2 Step unlock Car locator function True last door arming Back-up memory system Second channel auxiliary output 3rd channel auxiliary 115 db electronic siren CONVENIENCE FEATURES Multiple vehicle operation Dome light illuminated entry Window comfort lock feature Passive / manual arming Valet / override Panic function Trunk / hatch release output Dedicated trunk trigger input Lock / unlock outputs Lock / unlock in valet mode Remote chirp delete Siren or Horn output Pager output 2nd channel trunk trigger and shock by-pass Limited lifetime warranty PROGRAMMABLE FEATURES Chirp delete Manual / Passive arming Passive arming door locks Ignition control door locks Chanel 2 pulsed / momentary 3rd Channel momentary / latched Lock confirmation on/off Automatic re-arm Single / Double pulse locks Pathway illumination Arm voltage sense timer Siren / Horn output 2 step Unlock Door lock pulse timer |
Re: Alarma pe Logan
marfa:d
eu am una `maat` |
Re: Alarma pe Logan
imi poti spune la ce pret cu tot cu montaj? ms
| All times are GMT +2. The time now is 21:57. |
