Old 16-06-05, 09:06   #1
Soichiro
Guest
Posts: n/a
Default O noua generatie de motoare pe benzina ! ! !
A doua generatie de motoare pe benzina a aparut. El functioneaza pe baza a 4 perechi de cilindrii oscilativi in interiorul unui tub. Noul sistem elimina vibratiile, reduce semnificativ greutatea unui motor si ofera o putere mai mare decat corespondentul sau tip Otto.
Sursa: http://biz.yahoo.com/iw/050614/088680.html
Stirea:
2nd Generation Engine Completed
Tuesday June 14, 7:00 am ET
VANCOUVER, BC--(MARKET WIRE)--Jun 14, 2005 -- Rotoblock Corporation (OTC BB:ROTB.OB - News) is pleased to announce that it has completed the ground-up redesign and manufacture of its Oscillating Piston Engine -- a technologically advanced, high performance, 2nd generation prototype of its patented Oscillating Piston Engine. Assembly is nearly finished and the company expects to begin its initial test run within two weeks. The successful fulfillment of this key objective represents a major milestone on the road to the commercialization of this innovative product. Every indication shows that the Oscillating Piston Engine should surpass performance of current combustion engines on several levels.
The Oscillating Piston Engine's unique design includes novel features that are calculated to deliver notable performance gains over several fronts, ensuring the engine will compete favorably against any internal combustion engine in production today. In particular, this design dramatically simplifies a number of aspects associated with engine use and servicing, as it has only four primary moving sub-assemblies, no cumbersome valve train or water cooling system and only half as many discrete components as a conventional motor vehicle engine. The Oscillating Piston Engine is calculated to deliver significantly more horsepower than a conventional engine of equivalent weight and is therefore capable of delivering essentially any desired horsepower with a significantly lighter engine than regular combustion engines. This powerful, lightweight and uniquely simple engine can readily be seen to have significant advantages in applications where performance to weight ratio is a factor.
With the successful completion of the 2nd generation Oscillating Piston Engine, we will now be working on the next phase in the development and commercialization of this product. This phase involves the commencement of rigorous performance testing to be undertaken initially by Rotoblock scientists and then by independent third parties and potential industry partners. Included in this phase will be the testing of various alternate and hybrid fuels to further enhance the engine performance and environmental efficacy of the Oscillating Piston Engine.
Cum functioneaza:
http://www.rotoblock.com/howitworks.shtml
Studiati cu atentie graficele, sunt foarte interesante, in special al doilea grafic mai mare.
Ce parere aveti? Se va implementa cu succes?
Old 16-06-05, 14:44   #2
200SX
4 Speed Squad Member
200SX's Avatar
[4 Speed Squad]
Dracovenia asta e prototip sau deja echipeaza vreo masina?
parca mai era un post pe tema asta,
motorul asta nu e ceva in genul motorului rotativ doar ca asta are 4 camere ? daca da vedeti ca ma ie un topic pe tema asta si are si poze
Old 16-06-05, 18:57   #3
COObra
COObra's Avatar
foarte interesant
de laudat ca mai si lucreaza unii si mai inventeaza cate ceva
COObra is offline   Reply With Quote
Old 17-06-05, 00:42   #4
Soichiro
Guest
Posts: n/a
Se lucreaza intens si sunt destule patente, dar acesta este unul mai implementabil. Totusi, din cate vedeti, nu s-a renuntat la batranii cilindrii. Deci practic ar fi o e volutie mai deosebita. Sa vedem acum cine il va implementa. Poate peste 4-5 ani vom vedea si prima masina de serie cu asa ceva.
Old 17-06-05, 06:25   #5
COObra
COObra's Avatar
nu ma prea pricep la wankel dar parca este o derivatie a lui wankel, dar cu ceva imbunatatiri (pistoane cu segmenti care in caz de uzura se repara usor, etc)
pe de alta parte nu am vazut estimari de putere si daca nu ma insel nici de consum....si sa fiu al draku daca am inteles pana la urma ce sunt alea care se invart pe langa pistoane.
Old 18-06-05, 01:14   #6
ozzy
ozzy's Avatar
ma,dar eu din toata pagina aia in care arata frumos cum se arde gazu...nu am inteles o treaba: cum naiba se transmite miscarea de, si la pistoanele alea multe......doar am vazut pe viu un wankel desfacut si nu prea au legatura,asta e clar
ozzy is offline   Reply With Quote
Old 18-06-05, 07:28   #7
COObra
COObra's Avatar
vezi ca au o sectiune cu multe poze cu motorul desfacut si o sa vezi acolo cum vin bielele, bolturile si cum se transmite miscarea
