pret 215 eur
Vine complet fara cutie
Pt full spec cauta pe google.
Specificatii:
Sony MEX-BT5700U CD / MP3 / WMA Car Stereo with Bluetooth
USB 1-Wire & Front Auxiliary Input
MP3/WMA/AAC Playback With DM+
Wireless Card Remote (RM-X306)
Bluetooth® With Integrated Microphone
Amplifier Section
Speaker Impedance : 4-8 Ohms
Audio
Audio Format : BTM
Band : AM / FM
CD Playback : Wow and flutter-Below measurable limit
Digital-to-Analog Converter : 24bit
Frequency Response : 10-20,000Hz
Output Impedance : 4-8 Ohms
Preout Voltage : 4 volt
S/N Ratio : CEA2006 S/N 82 dB
Sensitivity (db) : FM: Usable sensitivity (75)(dBf): 10
Signal-to-Noise Ratio : CD: 120dB
Station Preset(s) : FM18/AM12
Tone Control(s) : Low: +/-10 dB at 60Hz (XPLOD) Mid: +/-10dB at 1kHz (XPLOD) High: +/-10dB at 10kHz (XPLOD)
Tuner Frequency Range : FM: Tuner Frequency Range(MHz): 87.5-107.9, MW: Tuner Frequency Range(kHz): 530-1710
Tuner Type : SSIR-EXA
Volume Control : Tel/Nav Attenuation
Wow and Flutter : Below Measurable Limit
Audio Features
Level Control : -8dB ~ +18dB
Capability
CD : Yes (CD-R/RW)
Component Compatible : Sony BUS Control with CD-Text
Convenience
Menu Options : Auto Title Scroll
Tilt Range : 45°
Convenience Features
CD Text Display : Yes
Illumination : Blue
On-Screen Clock : 12H
General
color : Chrome
Graphics
ormat(s) Supported : HFP 1.5, HSP, A2DP, AVRCP 1.3, PBAP
Inputs and Outputs
12V Trigger Output(s) : Power antenna Amplifier turn on
Analog Audio Input(s) (Total) : Front Aux-In
Antenna Terminal(s) : Aerial Input Terminal
Audio Out (Variable/Fixed) : Speaker outputs (sure seal connectors)
Digital Audio Input(s) : - Ability to use all forms of USB devices may vary as not all devices are compatible. This unit can be connected to the following iPods. Update your iPod to the latest software before you use it. -iPod Nano 1st generation* -iPod Nano 2nd generation (aluminum) -iPod Nano 3rd generation (video) -iPod 5th generation (video)* -iPod Classic -iPod Touch -iPhone * When you connect iPod Nano1st generation or iPod 5th generation, Passenger Control is not available. -This unit is compliant with MSC (Mass Storage Class) and MTP (Media Transfer Protocol) type USB devices compliant with the USB standard. -This unit cannot recognize USB devices via a USB hub. If you have any questions or problems concerning your unit that are not covered in this manual, consult your nearest Sony dealer.
Infrared Port : Remote Controller Input Terminal
Input(s) : BUS audio input terminal, Front USB5, Front Aux In
Remote Jack : Optional Wired Remote input
Remote Network Connection(s) : Bluetooth®6 Hands-Free and Audio Streaming Functionality
USB Port(s) : USB Full-Speed
Power
Input Power : 12 V DC car battery (negative ground (earth))
Output Power : 52W x4 High Power - 17 watts per channel minimum continuous average power into 4 Ohms, 4 channels driven from 20 Hz to 20 kHz with no more than 5% total harmonic distortion.
Power Consumption (in Operation) : 45W
Tuner
FM Usable Sensitivity : 10 dBf
Frequency Response : 20 - 15,000 Hz
S/N Ratio : 70 dB
Selectivity : 40 dB at 1 kHz
Stereo Separation : 40 dB at 1 kHz
Video Features
Display Technology : LCD
