Old 05-11-10, 07:11   #1
F.R.Sonic
F.R.Sonic's Avatar
[AfterDark Racing]
[SUBARU]
Question Fi X12 ----Vs---- SPL Dynamics V300S4
Merita Fi-u diferenta de bani?
Voi ce ma sfatuiti?
Fi X12 Pret cam 650 Lei (nou)
SINGLE 4 Ω
Fs: 35.8 Hz
Re: 2.9 Ohms/coil
Qms: 5.55
Qes: .47
Qts: .44
Mms: 126.1g
Cms: 1.6mm/N
Sd: 481cm^2
Vas: 50.7 l
Spl: 88.8dB 1W/1m
Bl: 13.2 N/A
Xmax: 18mm
Rms: 250W *
Sealed box: .6-1.1 cuft
Ported box: 1.6-2.2cuft
Sub OD: 12.500”
Cut ID: 11.125”
Mounting depth: .250”
Displacement: 0.08cuft
SPL Dynamics V300S4 Pret cam 350Lei (nou)
Size: 322mm ( 12" )
Power handling (RMS/Peak): 350/700 W
Nominal impedance: 4 Ohm
Mounting depth: 152 mm
Mounting diameter: 273 mm
Magnet weight: 80 oz
Voice Coil diameter: 51 mm ( 2" )
Voice Coil Type/Material: SVC / Black Aluminium
Fs: 30 Hz
Vas: 71.5 L
Qts: 0.466
Qes: 0.528
Qms: 3.938
Xmax (lin/peak): 10/20 mm (aici nu prea inteleg de ce sunt 2 valori...."lin/peak" ... ??? de ex la Fi care e trecut Xmax: 18mm "lin" sau "peak"?)
Re: 3.2 Ohm
Mms: 146 g
BL: 12.9 TM
Closed box: 26-35 L
Bass-Reflex box - Car / Hifi: 50 L + 4" port / length 36cm
Bass-Reflex box - Car / Loudmusic: 45 L + 4" port / length 18cm (Use Subsonic 30Hz)
ID:	1725600   Click image for larger version
ID:	1725601   Click image for larger version
F.R.Sonic is offline   Reply With Quote
Old 09-11-10, 00:41   #2
F.R.Sonic
F.R.Sonic's Avatar
[AfterDark Racing]
[SUBARU]
Unhappy Re: Fi X12 ----Vs---- SPL Dynamics V300S4
Nici o parere?
Old 17-11-10, 18:53   #3
F.R.Sonic
F.R.Sonic's Avatar
[AfterDark Racing]
[SUBARU]
Default Re: Fi X12 ----Vs---- SPL Dynamics V300S4
No opinion?
sa iau ieftinitura de spl dynamics?
Old 17-11-10, 20:05   #4
Lil' D
Lil' D's Avatar
La FI cursa e liniara. E o diferenta considerabila. Ai si posibilitate de recone in caz de ceva...
Old 17-11-10, 20:12   #5
F.R.Sonic
F.R.Sonic's Avatar
[AfterDark Racing]
[SUBARU]
Sa inteleg ca ai opta pt FI ?
Sincer eu as alege FI-ul dar ma gandesc ca e dublu la pret si ca putere e putin mai slabut ca si rms...desi nicicare nu e "monstru"
Old 17-11-10, 20:18   #6
Lil' D
Lil' D's Avatar
E discutabil daca as merge 100% sigur pe FI in cazul tau...
Daca poti, incearca un SSD, nu am preturile la indemana, dar nu cred ca iese mult mai scump ca si X-ul.
Team SQNLL
Old 17-11-10, 20:28   #7
F.R.Sonic
F.R.Sonic's Avatar
[AfterDark Racing]
[SUBARU]
M-am documentat eu inainte e cam dublu ca si pret dar e 800w rms si nu am statie capabila de asa ceva...
si din pacate nu pot investi inca intr-o statie deci trebuie sa ma limitez la ce am adica ceva maxim 350rms musai in 4Ohmi
£249 -SSD-u de 12'
£119 -X-u de 12'
preturile astea nu includ transport
X-u e £150 pana la usa mea la hunedoara.
de la importatorul FI in europa http://bladeice.com/products.php
Old 18-11-10, 22:07   #8
Bigu
Bigu's Avatar
personal eu refuz sa mai cred in puterile declarate de producator.
in 90% din cazuri preturile justifica potentialul si calitatea produsului (evident fiind constient de unde vine fiecare produs si cate taxe se platesc pana la end user)
Y!M dbig.sounds
S-A DESCHIS
Old 19-11-10, 11:44   #9
CLAUDIU_URBAN
CLAUDIU_URBAN's Avatar
sunt deacord cu bigu , am bobinat de curand un difuzor de 5000w rms firma americana si unul de 2000w rms firma nemteasca , bine acolo sunt asamblate componentele fiind produse in prc toate . si ala de 2000w rms avea bobina aproape dubla si ca spire si grosime decat cel de 5000w care mai era si pe 18''.
poate avea 5000w dar erau w chinezesti
deci un difuzor de calitate costa .
Incinte Subwoofere https://www.youtube.com/watch?v=V6FztSnQUHw
Rebobinari Difuzoare https://www.youtube.com/watch?v=u_XmDIFE_GY
piese difuzoare http://claudiuurban.blogspot.ro/
CLAUDIU_URBAN is offline   Reply With Quote
