Voi pentru care marca ati opta?Sa fiu mai precis intre un JBL GTO 755.6 sau doua Helix Dark Blue 4.
JBL
amplificator pe 6 canale (4 + 2)
putere
60W RMS x 4 + 107W RMS x 2 la 4 ohmi si ≤ 1% THD + N
160W x 2 + 300W x 1 la 4 ohmi si ≤ 1% THD + N
117W (canalele 1, 2, 3, 4) si 163W (canalele 5, 6) la 2 ohmi
raport semnal/zgomot 79dBA (1 watt la 4 ohmi)
raspuns in frecventa
10Hz – 47kHz (canalele 1, 2, 3, 4)
10Hz – 302Hz (channels 5, 6)
semnal maxim de intrare 6V
crossover electronic trece-jos 12 dB variabil
dimensiuni: (H x W x D) 475mm x 313mm x 60mm
HELIX
Power RMS / Musik at 4 x 4Ohm at 13,8 Volt
4 x 60/120 Watt
Power RMS / Musik at 4 x 2Ohm at 13,8 Volt
4 x 100/200 Watt
Power RMS/Musik 2 x 4 Ohm bridged
2 x 180/360 Watt
Total harmonic distortion< 0,03%
Signal to noise ratio> 93 dB
Bassboost adjustment 0-18 dB
Frequency range Highpass 15 Hz-4 kHz
Frequency range Lowpass 40 Hz-4 kHz
Frequency range Bandpass 15 Hz-4 kHz
Frequency range 10 Hz-30 kHz
TIM distortion< 0,04%
Input sensitivity 200 mV - 8 V
Fuse 2 x 25 A
Input impedance 10 kOhm
Dimensions (H/W/D) in mm 64 x 245 x 400
Weight netto 4,6 kg
Mentionez ca amplificatoarele sunt pentru un sistem cu 3 cai.
