Old 20-11-06, 14:40   #1
Duruselu
Audi Driver
Duruselu's Avatar
Default 2002 Mercedes-Benz CLK GTR Supersport
price $1 250 000 USD
engine 60 Degree V12
position Mid Longitudinal
aspiration Natural
valvetrain DOHC, 4 Valves per Cyl
displacement 7291 cc / 444.9 cu in
bore 91.5 mm / 3.6 in
stroke 92.4 mm / 3.64 in
power 536.9 kw / 720 bhp @ 6700 rpm
hp per litre 98.75 bhp per litre
drive wheels Mid Engine / RWD
front brakes Vented Carbon Fibre Discs w/6-Pot Calipers, Hydrualic Assist, ABS
f brake size 381 mm / 15.0 in
rear brakes Vented Carbon Fibre Discs w/4-Pot Calipers, Hydraulic Assist, ABS
r brake size 356 mm / 14.0 in
front wheels F 45.7 x 26.7 cm / 18 x 10.5 in
rear wheels R 45.7 x 31.8 cm / 18 x 12.5 in
front tire size 295/35 ZR18
rear tire size 345/35 ZR 18
steering Rack & Pinion w/Power Assist
f suspension Double Wishbones w/Push-Rod Acuated Coil Springs, Shock Absorbers, Anti-Roll Bar
r suspension Double Wishbones w/Push-Rod Acuated Coil Springs, Shock Absorbers, Anti-Roll Bar
wheelbase 2670 mm / 105.1 in
front track 1665 mm / 65.6 in
rear track 1594 mm / 62.8 in
length 1855 mm / 73.0 in
width 1950 mm / 76.8 in
height 1100 mm / 43.3 in
transmission 6-Speed Sequential w/Paddle-Shift Operation
gear ratios 3.235:1, 2.097:1, 1.560:1, 1.231:1
0 - 60 mph 3.6 seconds
Supercar Spotlig
ID:	178325   Click image for larger version
ID:	178326   Click image for larger version
ID:	178328   Click image for larger version
Right Foot Fanatics
Duruselu is offline   Reply With Quote
Old 20-11-06, 18:53   #2
B.v.L
B.v.L's Avatar
Default Re: 2002 Mercedes-Benz CLK GTR Supersport
masina facuta special pt. romania
B.v.L is offline   Reply With Quote
Old 21-11-06, 10:07   #3
silviu_fxx
silviu_fxx's Avatar
Indubitabil unul dintre cele mai renumite Mercedes-uri
silviu_fxx is offline   Reply With Quote
Old 21-11-06, 13:40   #4
ESPinoza
ESPinoza's Avatar
[Crazy Drivers]
mashina care ia creat probleme mclarenului F1 la vremea ei
ESPinoza is offline   Reply With Quote
Old 22-11-06, 18:45   #5
alex_102
alex_102's Avatar
baga tare masina??.. cam scumpa totusi..
alex_102 is offline   Reply With Quote
Old 04-12-06, 12:55   #6
tocatoru
tocatoru's Avatar
masina nu vrajeala credetzi ca e mai tare ca un ferrari sau lamborgini?
tocatoru is offline   Reply With Quote
Old 12-12-06, 08:55   #7
smtraxx
smtraxx's Avatar
E muult mai tare ca un lambo sau Ferrari.
Si pe deasupra..cine a luat locul lui McLarren..tot un Mercedes - Die neue SLR Vision!!
Bestiala masinarie!
smtraxx is offline   Reply With Quote
Old 12-12-06, 21:53   #8
bakal
bakal's Avatar
[Nissan]
frumoasa masina, as vrea sa pot conduce asa ceva.
nu cred ca va mai fi ceva la fel de spectaculos ca meclaren f1. aia va ramane o legenda, un standard pe care toate supermasinile vor sa-l atinga
got smoke, will travel
bakal is offline   Reply With Quote
Old 12-12-06, 22:23   #9
300ZX
300ZX's Avatar
Bolid,cred ca poate fi comparat chiar si cu enzo.
300ZX is offline   Reply With Quote
Old 17-12-06, 21:59   #10
LiviuTZ
LiviuTZ's Avatar
Nici nu este scump...
LiviuTZ is offline   Reply With Quote
Old 17-03-09, 01:15   #11
sebilica455
Audi Driver
sebilica455's Avatar
superba masian
sebilica455 is offline   Reply With Quote
Old 18-03-09, 09:55   #12
getedoi
getedoi's Avatar
ai inviat un thread vechi de 3 ani ca sa postezi "superba masina"???
getedoi is offline   Reply With Quote
Old 18-03-09, 11:22   #13
Outrageous
Outrageous's Avatar
Din 25 de CLK GTR care au fost fabricate doar 2 au beneficiat de motorul de 7.3L iar de sigla Super Sport doar una ,cea rosie din imagine, cealalta este argintie.
L.E. Au fost mai mult de 2 fabricate pentru ca sultanul din Brunei detinea 2 cu volanul pe dreapta , un coupe si un roadster. Deci au fost cel putin 4
Outrageous is offline   Reply With Quote
Old 19-03-09, 13:40   #14
Evoluzione
Saab Pilot
Evoluzione's Avatar
[FOTO]
Una dintre masinele mele preferate... Un vis
Evoluzione is offline   Reply With Quote
Old 28-03-09, 09:55   #15
carutasu
carutasu's Avatar
O masina perfecta, va ramane pentru totdeauna ca una dintre cele mai frumoase si de top supercaruri ever built.De cand am vazut prima data argintiul, am fost de parere ca pur si simplu aceasta masina e perfecta, nimic nu se mai poate modifica ( tuna) la aspectul ei exterior.Orice in plus ar strica.
Parerea mea e ca este peste Enzo si inca binisor.Enzo nu va avea niciodata carisma acestei masini (cum nu o va avea nici pe a McLaren-ului F1).
carutasu is offline   Reply With Quote
