2002 Mercedes-Benz CLK GTR Supersport
price $1 250 000 USD
engine 60 Degree V12 position Mid Longitudinal aspiration Natural valvetrain DOHC, 4 Valves per Cyl displacement 7291 cc / 444.9 cu in bore 91.5 mm / 3.6 in stroke 92.4 mm / 3.64 in power 536.9 kw / 720 bhp @ 6700 rpm hp per litre 98.75 bhp per litre drive wheels Mid Engine / RWD front brakes Vented Carbon Fibre Discs w/6-Pot Calipers, Hydrualic Assist, ABS f brake size 381 mm / 15.0 in rear brakes Vented Carbon Fibre Discs w/4-Pot Calipers, Hydraulic Assist, ABS r brake size 356 mm / 14.0 in front wheels F 45.7 x 26.7 cm / 18 x 10.5 in rear wheels R 45.7 x 31.8 cm / 18 x 12.5 in front tire size 295/35 ZR18 rear tire size 345/35 ZR 18 steering Rack & Pinion w/Power Assist f suspension Double Wishbones w/Push-Rod Acuated Coil Springs, Shock Absorbers, Anti-Roll Bar r suspension Double Wishbones w/Push-Rod Acuated Coil Springs, Shock Absorbers, Anti-Roll Bar wheelbase 2670 mm / 105.1 in front track 1665 mm / 65.6 in rear track 1594 mm / 62.8 in length 1855 mm / 73.0 in width 1950 mm / 76.8 in height 1100 mm / 43.3 in transmission 6-Speed Sequential w/Paddle-Shift Operation gear ratios 3.235:1, 2.097:1, 1.560:1, 1.231:1 0 - 60 mph 3.6 seconds Supercar Spotlig |
Re: 2002 Mercedes-Benz CLK GTR Supersport
masina facuta special pt. romania :)
Indubitabil unul dintre cele mai renumite Mercedes-uri
mashina care ia creat probleme mclarenului F1 la vremea ei :)
baga tare masina??.. cam scumpa totusi..
masina nu vrajeala credetzi ca e mai tare ca un ferrari sau lamborgini?
E muult mai tare ca un lambo sau Ferrari.
Si pe deasupra..cine a luat locul lui McLarren..tot un Mercedes - Die neue SLR Vision!! Bestiala masinarie! |
frumoasa masina, as vrea sa pot conduce asa ceva.
nu cred ca va mai fi ceva la fel de spectaculos ca meclaren f1. aia va ramane o legenda, un standard pe care toate supermasinile vor sa-l atinga |
Bolid,cred ca poate fi comparat chiar si cu enzo.
Nici nu este scump...
superba masian
ai inviat un thread vechi de 3 ani ca sa postezi "superba masina"??? :lol:
Din 25 de CLK GTR care au fost fabricate doar 2 au beneficiat de motorul de 7.3L iar de sigla Super Sport doar una ,cea rosie din imagine, cealalta este argintie.
L.E. Au fost mai mult de 2 fabricate pentru ca sultanul din Brunei detinea 2 cu volanul pe dreapta , un coupe si un roadster. Deci au fost cel putin 4 :D |
Una dintre masinele mele preferate... Un vis :love:
O masina perfecta, va ramane pentru totdeauna ca una dintre cele mai frumoase si de top supercaruri ever built.De cand am vazut prima data argintiul, am fost de parere ca pur si simplu aceasta masina e perfecta, nimic nu se mai poate modifica ( tuna) la aspectul ei exterior.Orice in plus ar strica.
| All times are GMT +2. The time now is 16:10. |
