Old 25-11-05, 01:44   #1
radical
Default Maybach Exelero
Ce ziceti de noul Maybach?
Engine
Construction: V-engine, 60° bank angle
Number of cylinders: 12
Cubic capacity (cm³): 5908 cm³
Performance (kW): 515
(Hp): 700
at revs/min: 5000
Max. torque: (Nm): 1020 at revs/min: 2500
Dimensions and weights
Wheelbase: (mm): 3390
Length: (mm): 5890
Breadth: (mm): 2140
Height: (mm): 1390
Unladen weight: (kg): 2660
Permitted total weight: (kg): 2960
Chassis and Performance
Wheel mounting
front: Double wishbone axle
rear: multi link rear axle
Tires: Fulda Carat Exelero
front: 315/25 ZR 23
rear: 315/25 ZR 23
Brakes: Internally ventilated disc
Type front: 4x4 piston fixed caliper (2 calipers)
Diameter (mm): 376
Type rear: 2x4 piston fixed caliper
Diameter (mm): 355
ABS / ESP
Maximum speed (km/h): 351,45
Acceleration from 0 to 100 km/h (s): 4,4
ID:	53514   Click image for larger version
ID:	53515   Click image for larger version
ID:	53517   Click image for larger version
ID:	53518   Click image for larger version
ID:	53520   Click image for larger version
ID:	53521   Click image for larger version
ID:	53523   Click image for larger version
radical is offline
Old 25-11-05, 06:48   #2
sil4tuning
Purtator cuvant SUN RACERS
sil4tuning's Avatar
[Sun Racers]
esti a III a persoana care prezinta DIN NOU excelero si a II a in intervalul a doua zile fiti mai atenti si cautati intai despre subiectul care doriti sa il dezbateti
CDTI
sil4tuning is offline
Old 25-11-05, 09:22   #3
RoSonic
4 Speed Squad Member
RoSonic's Avatar
[4 Speed Squad]
cum a zis si sil4tuning, nu mai postati subiecte existente!
Folositi search!
RoSonic is offline
