Maybach Exelero
11 Attachment(s)
Ce ziceti de noul Maybach?
Engine Construction: V-engine, 60° bank angle Number of cylinders: 12 Cubic capacity (cm³): 5908 cm³ Performance (kW): 515 (Hp): 700 at revs/min: 5000 Max. torque: (Nm): 1020 at revs/min: 2500 Dimensions and weights Wheelbase: (mm): 3390 Length: (mm): 5890 Breadth: (mm): 2140 Height: (mm): 1390 Unladen weight: (kg): 2660 Permitted total weight: (kg): 2960 Chassis and Performance Wheel mounting front: Double wishbone axle rear: multi link rear axle Tires: Fulda Carat Exelero front: 315/25 ZR 23 rear: 315/25 ZR 23 Brakes: Internally ventilated disc Type front: 4x4 piston fixed caliper (2 calipers) Diameter (mm): 376 Type rear: 2x4 piston fixed caliper Diameter (mm): 355 ABS / ESP Maximum speed (km/h): 351,45 Acceleration from 0 to 100 km/h (s): 4,4 |
esti a III a persoana care prezinta DIN NOU excelero si a II a in intervalul a doua zile :roll: fiti mai atenti si cautati intai despre subiectul care doriti sa il dezbateti
cum a zis si sil4tuning, nu mai postati subiecte existente!
Folositi search! |
| All times are GMT +2. The time now is 07:02. |
