Originally Posted by Iron Teeth
sal, m-ar interesa kitt-ul de airbrush, daca mai poti aduce ar fi super!
Pot aduce din State urmatorul kit de airbrush:
Master Airbrush Airbrushing System with Createx 20 Color Paint Set, Book, Cups, Sticks...
Includes G44 Airbrush that's Loaded with Features!
Systems Includes:
• Powerful Air Compressor with Tank
• Precision High Detail Control Airbrush
• How To: Airbrush Book
• 20 Paint Colors to get you Started
• Plus everything to keep it Organized:
• Holder for up to 4 Airbrushes
• Cleaning Pot, 100 Mix Cups & Sticks
Mai multe detalii despre el gasiti aici :
Complete Master Airbrush System with Accessories
Top Selling High Performance Airbrush!
High Detail Control Airbrush that's loaded with extra features such as:
• Precision Machined 4 Piece Matched Airbrush
• Head System for fine atomization with extra
• control and increased detail.
• Air Control Regulation Valve provides superior
• control of airflow at the head of the airbrush.
• Applications: Where accurate spray control
• is required to do highly detailed work: Auto
• Graphics, Fine Illustration, Nails, Arts, Etc....
Ideal Holiday Christmas Kit
System Includes:
• Master Airbrush Brand Model G44 Precision Dual-Action Gravity Feed Airbrush
• (Includes a Full 1 Year Warranty) with a 0.2mm needle/nozzle and a 1/3 oz. funnel
• shaped gravity fluid cup along with a 6' Braided Hose
• Airbrush-Depot Brand Model TC-20T Maintenance Free Air Compressor with Tank
• (Includes a Full 2 Year Warranty) that has a Automatic On/Off Shutoff, Air Regulator with
• Gauge & Water Trap Filter
• Createx Brand 20 Popular Color Airbrush Paint Set
• Airbrush Book: How To Secrets for Advanced Airbrush Art
• 3 in 1 Use Airbrush Cleaning Pot along with Airbrush Cleaning Solution
• 100 1 oz. Plastic Mixing Cups and 100 Mixing Sticks
• Universal Airbrush Holder for up to 4 Airbrushes
• Airbrush Quick Disconnect: Quick Release your Airbrush for fast Cleaning
Model G44 Airbrush Specifications:
• Dual-Action Trigger Air/Fluid Control
• Internal Mix Thoroughly Atomized Spray Pattern
• 1/3 oz. (9 cc) Gravity Feed Fluid Cup
• 0.2 mm Needle/Nozzle with 4 Part Precision
• Matched Head System
• Hairline to 1" Wide Spray Pattern
• 15-50 PSI Working Pressure
• Solvent Resistant Teflon Needle Packing
• Nozzle Wrench and 2 cc Eye Dropper
• Molded Plastic Storage Case
• Full 1 Year Warranty, so you can be assured
• of Quality and Reliability.
Applications:
• Illustration
• Fine/Commercial Art
• Photo Retouching
• Custom Automotive
• Motorcycle Graphics
• Nails & Cosmetics
• Taxidermy/Lures
• Models/RC's/Trains
• Hobbys and Crafts
• Miniatures Spray & Color Media:
• Watercolors
• Acrylics
• Inks and Dyes
• Automotive Urethanes
• Lacquers & Enamels
Model G44 Airbrush Features and Benefits:
• Made with High Quality Precision Components that enable this airbrush to work
• efficiently while providing exceptional atomization and accurate spray control.
• The Precision Machined 4 Piece Matched Airbrush Head System provides fine
• atomization for extra control and increased detail.
• Removing the Needle and Nozzle Caps enable you to spray the full range of texture
• and stippling effects.
• The Crown Cap prevents paint build up at the nozzle. Removing the Crown Cap and
• Nozzle Cap enables you to spray the full range of texture and stippling effects.
• Provides superior control of airflow at the head of the airbrush through the Air
• Control Regulation Valve. A quick turn of the valve can instantly take you from full
• atomization to extra fine detail. Fully opening the Valve makes it very easy to clean
• during color changes.
• Includes Solvent Resistant Teflon Needle Packing which will prolong the life of the
• airbrush. The Teflon needle seal enables you to use Solvent Based Automotive Paints
• such as Urethanes, Lacquers and Enamels.
• Cutaway Handle that allows you to quickly flush and clean passageways by grabing
• the needle chucking nut.
• Funnel shaped gravity fluid cup enables the airbrush to be used with drops of fluid.
• Fluid Control Knob for easy adjustment and control of paint flow.
• Ability to spray a Hairline to 1" Wide Pattern.
• All Parts available and in stock for this airbrush.
Airbrush-Depot Model TC-20T Tank Air Compressor Specifications:
• Type: Single Cylinder Piston Compressor w/Air Tank
• Power: 1/5 Horse Power
• Voltage: 110-120V / 60HZ
• Air Control: Pressure Regulator with Gauge and
• Water Trap Filter.
• Air Delivery: 25 Liters/Minute; 0.8 CFM @ 60 PSI
• Working Pressure: 15-45 PSI
• Maximum Pressure: Factory Preset at 60 PSI,
• without Preset Control 100 PSI
• Auto Stop/Start: Stop at 60 PSI, Start at 35 PSI
• Air Tank: 0.92 Gallon (3.5 Liters)
• Safety Pressure Relief Valve
• Connections: 1/8'' BSP
• Dimensions: 13" H x 6.5" W x 13.5" L
• Weight: 11.5 LBS (5.2KG)
• Electric Cord: 6 foot, Certificate: CE
Airbrush-Depot TC-20T Air Compressor with Tank Features:
• Powerful: At 1/5 Horsepower this unit delivers more Air Volume (CFM) and Air
• Pressure (PSI) than any airbrush demands.
• Portable: Light-Weight and Compact with a built in carrying handle for Easy Handling
• and Storage.
• Precise Air Adjustment: True Diaphragm Pressure Regulator with Gauge and Water
• Trap Filter that provides precise adjustment of airflow and ensures clean, dry air.
• Automatic On/Off Shutoff: Preset for automatic turn off when air tank reaches 60
• PSI. Preset for automatic turn on when air tank pressure is below 35 PSI. The
• reduced running time means there will less motor wear and less heat-related moisture
• enabling a longer compressor life.
• Constant Pressure and Zero Pulsation: Air is drawn from the large air storage tank
• providing you a constant regulated pressure. There's zero pulsation because air is
• drawn from the tank which eliminates any pulsation effect from the pistons.
• "Air-On-Demand": Designed to work only when you do, produces air on demand at
• the your regulated pressure.
• Thermally Protected: Automatically turns itself off if the unit becomes over heated.
• Maintenance Free: Oil-less Piston Motor
• Low Noise: Very Quiet Operation, only 59 db.
Informatii pe PM sau 0765210011 Bogdan.
O zi buna
