Old 22-10-09, 16:51   #1
elfu_pupacios
Default 1.3 cdti_turbo mai mare
Sal.
Am un opel corsa c 2005 1.3 cdti motor: z13dt 70 cp/4000 rpm. Din fabrica are o turbina 3k model KP35. Ce turbina mai mare merge pusa? si ce alte modificari sunt necesare.
Am gasit un articol cu niste modificari facute de opel pana la 110 cp/4000-4500rpm pe acest motor insa montat pe eco_Speedster : " Opel enhanced pressure in the common-rail fuel system from the stock level—1400 bar (20,319 psi)—to 1600 (23,222), dropped the compression ratio from 18:1 to 16:1, installed six-hole injectors, added an air-to-water intercooler, and bolted on a 3K-Warner variable-turbine turbocharger with max boost of 1.4 bar (20.3 psi). That's a bunch of boost, enough to produce instant meltdown in a gasoline engine. But things are different in diesels, since detonation is a nonissue."
elfu_pupacios is offline   Reply With Quote
Old 29-10-09, 00:18   #2
elfu_pupacios
Default Re: 1.3 cdti_turbo mai mare
nici o parere? sa abandonez proiectul?
Old 29-10-09, 07:16   #3
bluey
Audi Driver
Un chiptuning ceva mai agresiv ar trebui sa te duca aproape de 100cp.
Cu ceva fum in schimb.
Apoi faci calculul de turbina.
Cred ca un vnt15 ar trebui sa iti faca treaba daca turbina stock are geometrie variabila.
Stock is for woosies
Smoking is for woosies
Old 24-11-09, 08:37   #4
MasterTuner
MasterTuner's Avatar
Noi putem sa-ti facem o turbina hybrid care arat pe afara identic cu a ta si cu care sa poti sa scoti 120 cp. Am facut de exemplu mai multe Loganuri de 120+.
TUNING TO PERFECTION
www.mastertuner.ro
Bucuresti, Teiul Doamnei 92
Tel.:0722275522/021 242 42 81
Old 03-12-09, 16:24   #5
ZooM-ZooM
Honda Driver
ZooM-ZooM's Avatar
[4 Speed Squad]
[Honda]
eu pe corsa mea am acelasi motor + soft. dar crede ma ca e suficient pentru caroseria ei.
ZooM-ZooM is offline   Reply With Quote
