Go Back   Forum 4Tuning > Masini & Tuning > MASINA MEA > HONDA - ACURA > Honda - Acura tuning
Old 08-10-07, 05:33   #1
dj05dpx
Guest
Posts: n/a
Default k20a in Lotus
This is the Prototype Racing Lotus Exige, equipped with a 240 HP Honda K20A engine and 6 speed LSD trans. The additional 20 HP was obtained by re-mapping the ECU. Further development of the intake and exhaust systems, as well as more ECU work will result in even more HP without any internal engine modification. Click HERE for K20A engine specs.
My European distributor and I drove the Exige on the ALMS circuit at the California Speedway on Sept. 22, and the power delivery of this engine is nothing short of fantastic. Excellent Torque is there everywhere in the rev range, the transition into VTEC is nearly seamless, and I found myself going 240 KPH (149 MPH) just prior to entering the chicane they included in the 17 degree banked oval portion of the course. An F355 Ferrari was only able to manage 210 KPH (130 MPH) on the same section of the course.
The car's wet weight with 25 litres of fuel is 750 Kg, front=295 Kg (39.3%) rear=455 Kg (60.7%).
I'm pleased with the car's handling and performance, but the original brakes are far from adequate, so I'll be developing a much more confidence inspiring braking system very soon. Dynamometer testing will begin later this week, and the resulting graphs will be published here. We're hoping to have this conversion kit available by the first of March, 2003. Below are more pictures of the engine installation.
Nu e nevoie sa mai traduc,intelegeti voi inglish ca toti vorbeste amestecat.
ID:	363284   Click image for larger version
ID:	363285   Click image for larger version
Old 08-10-07, 23:01   #2
Nicknamed_13
Nicknamed_13's Avatar
[Honda]
Default Re: k20a in Lotus
Yeap. Este un motor super. Puternic, usor, raspunde bine la acceleratie si este si fiabil.
Motoarele Honda sunt cele mai folosite motoare in astfel de transplanturi.
Ce ma mira este faptul ca nu au folosit un motor S2000.
"WARNING!!!! Objects seen in the mirror appear to be losing!"
"Let's try it again from a roll"
Honda Prelude H22A JDM Spec
https://forum.4tuning.ro/127-masina-mea-honda-acura/56205-93-prelude-type-jdm-2-2i-vtec-h22a.html
Nicknamed_13 is offline   Reply With Quote
Old 09-10-07, 11:31   #3
fanete
fanete's Avatar
[Honda]
pei apoi ce faceau cu transmisia...? motorul s200 e fata , tractiune spate... era muuuult mai complicat.
fanete is offline   Reply With Quote
