Go Back   Forum 4Tuning > Masini & Tuning > MASINA MEA > BMW > BMW tuning
Old 23-06-05, 18:55   #1
blowwind
Observator 4tuning
blowwind's Avatar
[Honda]
[Street Zone]
Default 2001 Lemans Blue M5
After sleeveing the block and fabricating a new pully set up we feel that a goal of 1000hp is obtainable. However due to the owners wish to have this car maintainable as a “bulletproof” daily driver it has been detuned to 800rwhp.
Modificari.....
Engine Internals
Cryo'd block
Coated block
Custom Darten flanged steel sleeves were installed to eliminate the concerns with the OEM Alusil coated aluminum cylinder bores
Custom spec'd Arias 9.5 CR pistons were fabricated
Custom rings were spec'd for this project
Custom spec'd Carrillo rods
New head and main bolts
Multi-layered head gasket
Fully ported and flow matched cylinder heads
New over sized Stainless valves (1mm greater diameter)
New springs
New Guides
New Retainers and keepers
Schrick Cams
New construction of crank bearing
Micro polished crank
During the course of the rebuild all soft items such as water pump, thermostat, etc. were replaced.
Engine Externals
Powder coated valve covers and lower plenum
D/A Custom CF intake
D/A Custom CF plenum cover
Vortech D/A Shadowman Custom T1 Blower
D/A Custom Fuel Rail
D/A Custom Fuel Injectors , a total of 16 injectors operating in this system
D/A Custom Velocity stacks with integrated injector bosses
D/A Custom modified lower plenum
D/A Custom oil separator and crankcase breather system
D/A Custom fully programmable by-pass system
D/A Custom billet lower pulley with Supercharger drive integrated
Pre-loaded self adjusting Supercharger belt tensioner
AquaMist injection, fully map able system
Custom water/air heat exchanger
Custom liquid charge cooler
Nitrous Express N-tercooler
Relocated the oil filter and the power steering reservoir from the left to right side.
D/A Custom stainless steel oil transfer manifolds under the motor
Extensive use of Aero Quip lines and fittings throughout the build
High efficiency radiator
Electric fan conversion
Supersprint 4-1 Coated Headers
HJS Custom Metal Cats
Supersprint X-pipe
Kelleners Sport exhaust
Engine Management
D/A Custom Shadowman DME and system integration Software Program
Desno Iridium Plugs
Ignition Solutions plasma coils
HKS O2 and knock monitor aka A/F Knock Amp with A/F monitoring integrated
Drive train
UUC Motorwerks Stage III 6puck carbon Clutch
UUC Motorwerks LWFW
Custom Driveshaft
Koala Motorsport prepared Diff with 3.45 gears
Rear Sub frame brace
Suspension
AFC DFC suspension
Eibach Sway bars, front and rear
Rogue Engineering Sway bar brackets
Brakes
Front- 8 piston 15” rotors Brembo Lemans series
Rear- 4 piston 13.5” rotors Brembo Lemans series
Exterior
Wheels OZ Superlegerra III
Tires Pirelli P-Zero Rosso 275 at the front and 295 's bringing up the rear
Body
ACS Front Canards
Rieger GTM Side skirts
ACS rear diffuser
ACS rear window spoiler
ACS 3pc lip wing
Euro 6000K Xenon light upgrade
Chrome MPower ///M oil cap
Interior
UUC RK5 Shift knob and Ebrake pkg
UUC Evo III w/ DSSR
TI pedals
Bimian Interior Xenon light upgrade
Blitz BLM series gauges, EGT and Boost
pt mai multe informatzii ...
http://www.discovery-automotive.com/...c_Content&id=4
ID:	31345   Click image for larger version
ID:	31346   Click image for larger version
ID:	31348   Click image for larger version
pround member of Street Zone
Honda Civic TypeS - VW Polo 1.2 - Subaru Forester 2.5XT - Infiniti FX37S
VAND PEUGEOT 307 CC
VAND SAAB 9-3 1.8t
blowwind is offline   Reply With Quote
Old 23-06-05, 19:23   #2
B 68 VLD
No comment.
B 68 VLD is offline   Reply With Quote
Old 23-06-05, 20:35   #3
pdw
Am vazut pe site-ul respectiv ca mai are si un frate geaman: un M5 negru.
pdw is offline   Reply With Quote
Old 23-06-05, 20:37   #4
c i k y
Dacia Driver
c i k y's Avatar
nu am ce spune despre masini ca asta..nu pot sa fac critici ..e cea mai tare imi place
c i k y is offline   Reply With Quote
Old 23-06-05, 20:50   #5
AlexT
[Midnight Racers]
o masina extraordinara
AlexT is offline   Reply With Quote
Old 23-06-05, 21:12   #6
baghy83
o vreauuuuuuuuuuuu
baghy83 is offline   Reply With Quote
Old 23-06-05, 21:15   #7
AlexT
[Midnight Racers]
Default Re:
Originally Posted by \"baghy83\"
o vreauuuuuuuuuuuu
si eu, dar cine nu si-ar dori una?
Old 23-06-05, 22:53   #8
baghy83
Default Re:
o vreauuuuuuuuuuuu
pai e chiar faina.prefer asta decat enzo-ala tiganesc
Old 24-06-05, 09:21   #9
mike20
Seat Driver
mike20's Avatar
[SEAT]
vai...cat de bine poate sa arate motoru`.....ma innebunseste....
mike20 is offline   Reply With Quote
Old 24-06-05, 09:31   #10
the_mav
the_mav's Avatar
:P :P :P
sleep baby, sleep....
the_mav is offline   Reply With Quote
Old 13-08-05, 14:18   #11
BASU
BASU's Avatar
super tare...bmw-ul e bmw
BASU is offline   Reply With Quote
Old 30-08-05, 23:21   #12
myky
myky's Avatar
myky is offline   Reply With Quote
Old 31-08-05, 00:25   #13
Skillzu
BMW Specialist
Skillzu's Avatar
crima si pedeapsa....asta inseamna o masina modificata..nu nfs sau FNF...asta da..sleeper....cele mai neorocite amsini..bomba!
Old 31-08-05, 08:24   #14
ZanDer
ZanDer's Avatar
hmz ... cum naiba or bagat atatea sub capota aia ...
ZanDer is offline   Reply With Quote
Old 01-09-05, 09:13   #15
CTA
Imi place enorm demult.
CTA is offline   Reply With Quote
