-   BMW tuning (https://forum.4tuning.ro/138-bmw-tuning.html)
-   -   2001 Lemans Blue M5 (https://forum.4tuning.ro/138-bmw-tuning/6187-2001-lemans-blue-m5.html)
blowwind 23-06-05 18:55
2001 Lemans Blue M5
After sleeveing the block and fabricating a new pully set up we feel that a goal of 1000hp is obtainable. However due to the owners wish to have this car maintainable as a “bulletproof” daily driver it has been detuned to 800rwhp.
Modificari.....
Engine Internals
Cryo'd block
Coated block
Custom Darten flanged steel sleeves were installed to eliminate the concerns with the OEM Alusil coated aluminum cylinder bores
Custom spec'd Arias 9.5 CR pistons were fabricated
Custom rings were spec'd for this project
Custom spec'd Carrillo rods
New head and main bolts
Multi-layered head gasket
Fully ported and flow matched cylinder heads
New over sized Stainless valves (1mm greater diameter)
New springs
New Guides
New Retainers and keepers
Schrick Cams
New construction of crank bearing
Micro polished crank
During the course of the rebuild all soft items such as water pump, thermostat, etc. were replaced.
Engine Externals
Powder coated valve covers and lower plenum
D/A Custom CF intake
D/A Custom CF plenum cover
Vortech D/A Shadowman Custom T1 Blower
D/A Custom Fuel Rail
D/A Custom Fuel Injectors , a total of 16 injectors operating in this system
D/A Custom Velocity stacks with integrated injector bosses
D/A Custom modified lower plenum
D/A Custom oil separator and crankcase breather system
D/A Custom fully programmable by-pass system
D/A Custom billet lower pulley with Supercharger drive integrated
Pre-loaded self adjusting Supercharger belt tensioner
AquaMist injection, fully map able system
Custom water/air heat exchanger
Custom liquid charge cooler
Nitrous Express N-tercooler
Relocated the oil filter and the power steering reservoir from the left to right side.
D/A Custom stainless steel oil transfer manifolds under the motor
Extensive use of Aero Quip lines and fittings throughout the build
High efficiency radiator
Electric fan conversion
Supersprint 4-1 Coated Headers
HJS Custom Metal Cats
Supersprint X-pipe
Kelleners Sport exhaust
Engine Management
D/A Custom Shadowman DME and system integration Software Program
Desno Iridium Plugs
Ignition Solutions plasma coils
HKS O2 and knock monitor aka A/F Knock Amp with A/F monitoring integrated
Drive train
UUC Motorwerks Stage III 6puck carbon Clutch
UUC Motorwerks LWFW
Custom Driveshaft
Koala Motorsport prepared Diff with 3.45 gears
Rear Sub frame brace
Suspension
AFC DFC suspension
Eibach Sway bars, front and rear
Rogue Engineering Sway bar brackets
Brakes
Front- 8 piston 15” rotors Brembo Lemans series
Rear- 4 piston 13.5” rotors Brembo Lemans series
Exterior
Wheels OZ Superlegerra III
Tires Pirelli P-Zero Rosso 275 at the front and 295 's bringing up the rear
Body
ACS Front Canards
Rieger GTM Side skirts
ACS rear diffuser
ACS rear window spoiler
ACS 3pc lip wing
Euro 6000K Xenon light upgrade
Chrome MPower ///M oil cap
Interior
UUC RK5 Shift knob and Ebrake pkg
UUC Evo III w/ DSSR
TI pedals
Bimian Interior Xenon light upgrade
Blitz BLM series gauges, EGT and Boost
pt mai multe informatzii ...
http://www.discovery-automotive.com/...c_Content&id=4
B 68 VLD 23-06-05 19:23
No comment. :shock:
pdw 23-06-05 20:35
Am vazut pe site-ul respectiv ca mai are si un frate geaman: un M5 negru.
c i k y 23-06-05 20:37
nu am ce spune despre masini ca asta..nu pot sa fac critici ..e cea mai tare :wink: imi place
AlexT 23-06-05 20:50
o masina extraordinara
baghy83 23-06-05 21:12
o vreauuuuuuuuuuuu :shock: :D :D :D
AlexT 23-06-05 21:15
Re:
si eu, dar cine nu si-ar dori una?
baghy83 23-06-05 22:53
Re:
pai e chiar faina.prefer asta decat enzo-ala tiganesc
mike20 24-06-05 09:21
vai...cat de bine poate sa arate motoru`.....ma innebunseste....
the_mav 24-06-05 09:31
:wink: :wink: :P :P :P
sleep baby, sleep.... :twisted: :twisted: :twisted: :twisted: 8)
BASU 13-08-05 14:18
super tare...bmw-ul e bmw :D
myky 30-08-05 23:21
:) :D :lol: :shock:
Skillzu 31-08-05 00:25
crima si pedeapsa....asta inseamna o masina modificata..nu nfs sau FNF...asta da..sleeper....cele mai neorocite amsini..bomba! :D
ZanDer 31-08-05 08:24
hmz ... cum naiba or bagat atatea sub capota aia ...
CTA 01-09-05 09:13
Imi place enorm demult. :!:
