Old 01-03-09, 15:58   #1
popasan
popasan's Avatar
Exclamation Motor si cutie pe dacie, de care???
Salut, am tot vazut puse pe dacii motoare de vw golf II (1.8 16v), de renault williams (1.8 16V), iar cutii de viteze de passat, audi 80, r21, r18.
Ce motor si cutie ar fi cele mai performante?
popasan is offline   Reply With Quote
Old 03-03-09, 09:49   #2
adrian_YLI
Default Re: Motor si cutie pe dacie, de care???
poti pune de care vrei
trebui sa te hotaresti
amandoua sunt bune
motor de golf II cutie de passat
si motor de renault williams cutie de r21
adrian_YLI is offline   Reply With Quote
Old 03-03-09, 19:53   #3
Bengy_BLS
Bengy_BLS's Avatar
cel mai echilibrat dupa parerea mea este(r19) F3p d700 , 1800cmc , 110cp , 8 valve , cu o cutie de dacie papuc modificata sau de fuego , r18 etc. ar mai fi renumitul f7p 1.8 16 135cp cunoscut pe clio si sub F16.ie
Bengy_BLS is offline   Reply With Quote
Old 03-03-09, 20:02   #4
popasan
popasan's Avatar
Default Motor si cutie pe dacie, de care???
Ce ziceti de F4R?
(F4R RS normally-aspirated 2.0 16V engine which delivers 197hp at 7,250rpm and maximum torque of 215Nm at 5,550rpm)
Si cutie de R21 Turbo (UN1), cutia asta se poate pune pe motoru ala?
Iar in cutie un (Quaife ATB Helical LSD differential)
Renault 21 Turbo --- 2.0 L (1995 cc) petrol SOHC 8-valve I4 MPI turbo; 175 bhp (129 kW); top speed: 227 km/h (141 mph) ; 0-100 km/h : 7.2 s (available in Turbo and Turbo Quadra models)....
Name:	New Clio Renault Sport is powered by the F4R RS normally-aspirated 2.0 16V engine which delivers.jpg
ID:	816363   Click image for larger version
Name:	renault 21 turbo gearbox (use a Renault 21-25 'UN1' Type unit).jpg
ID:	816364   Click image for larger version
Name:	Renault 30 UN1 Quaife ATB Helical LSD differential.jpg
Old 16-03-09, 21:57   #5
flocea_ro_ab
Dacia Driver
flocea_ro_ab's Avatar
vrei sa iti faci dacie sau ?
flocea_ro_ab is offline   Reply With Quote
