A 210 Evolution (by AMG) cu jante OZ Ultraleggera pe 16" si gume Continental PremiumContact.
Cam asta e masinutza mea...defapt a tatalui meu ca inca nu am implinit 18 ani...
General
Manufacturer Mercedes-Benz
Model A 210 Evolution
Powertrain Layout Front Engine / RWD
Base Price Not Available
Dimensions
Length 3640 mm / 143.3 in
Width 1719 mm / 67.7 in
Height 1587 mm / 62.5 in
Wheelbase 2423 mm / 95.4 in
Weight 1165 kg / 2568 lbs
Front / Rear Track F 1497 mm / 58.9 in
R 1462 mm / 57.6 in
Engine
Configuration 2.1 Liter 59° Inline 4
Valvetrain SOHC 2 Valves / Cylinder
Displacement 2084 cc / 127.2 cu in
Power 104.4 kW / 140.0 bhp at 5500 rpm
Torque 205.0 Nm / 151.2 ft lbs at 4000 rpm
Bore 84.0 mm / 3.31 in
Stroke 94.0 mm / 3.70 in
Compression Ratio 11.0:1
Bhp / Liter 67.18 bhp
Redline 6000 rpm
Chassis & Body
Body / Frame Not Available
Steering Rack & Pinion Power Steering w/
Electronic Controlled Power Steering Pump
Brake Type Hydraulic Dual-Circuit Braking System w/ Internally Ventilated & Cross-Drilled Discs at the Front, Solid Brake Discs at the Rear, Vacuum Booster, Brake Assist, Handbrake, ASR, ESP & ABS
Brake Size Not Available
Wheels F 43.2 x 17.8 cm / 17.0 x 7.0 in
R 43.2 x 17.8 cm / 17.0 x 7.0 in
Tyres F 205/40ZR-17
R 205/40ZR-17
Transmission
Gear Type 5 Speed Manual
Final Drive 3.72:1
1st Gear Ratio 3.27:1
2nd Gear Ratio 1.92:1
3rd Gear Ratio 1.34:1
4th Gear Ratio 1.03:1
5th Gear Ratio 0.82:1
Performance
Top Speed 203.0 kph / 126.1 mph
0 - 62 mph 8.2 seconds
0 - 100 mph Not Available
0 - ¼ mile Not Available
EPA City / Highway Not Available
http://www.supercarsite.net/a_210_evolution.htm
