-   Masina mea Mercedes (https://forum.4tuning.ro/128-masina-mea-mercedes.html)
-   -   A 210 Evolution (by AMG) (https://forum.4tuning.ro/128-masina-mea-mercedes/22566-210-evolution-by-amg.html)
Dirty Pusherman 27-08-06 02:29
A 210 Evolution (by AMG) cu jante OZ Ultraleggera pe 16" si gume Continental PremiumContact.
Cam asta e masinutza mea...defapt a tatalui meu ca inca nu am implinit 18 ani... :lol:
https://img246.imageshack.us/img246/2...amg1ci6.th.jpghttps://img218.imageshack.us/img218/5...amg2nj9.th.jpghttps://img155.imageshack.us/img155/8...amg3fd1.th.jpg
General
Manufacturer Mercedes-Benz
Model A 210 Evolution
Powertrain Layout Front Engine / RWD
Base Price Not Available
Dimensions
Length 3640 mm / 143.3 in
Width 1719 mm / 67.7 in
Height 1587 mm / 62.5 in
Wheelbase 2423 mm / 95.4 in
Weight 1165 kg / 2568 lbs
Front / Rear Track F 1497 mm / 58.9 in
R 1462 mm / 57.6 in
Engine
Configuration 2.1 Liter 59° Inline 4
Valvetrain SOHC 2 Valves / Cylinder
Displacement 2084 cc / 127.2 cu in
Power 104.4 kW / 140.0 bhp at 5500 rpm
Torque 205.0 Nm / 151.2 ft lbs at 4000 rpm
Bore 84.0 mm / 3.31 in
Stroke 94.0 mm / 3.70 in
Compression Ratio 11.0:1
Bhp / Liter 67.18 bhp
Redline 6000 rpm
Chassis & Body
Body / Frame Not Available
Steering Rack & Pinion Power Steering w/
Electronic Controlled Power Steering Pump
Brake Type Hydraulic Dual-Circuit Braking System w/ Internally Ventilated & Cross-Drilled Discs at the Front, Solid Brake Discs at the Rear, Vacuum Booster, Brake Assist, Handbrake, ASR, ESP & ABS
Brake Size Not Available
Wheels F 43.2 x 17.8 cm / 17.0 x 7.0 in
R 43.2 x 17.8 cm / 17.0 x 7.0 in
Tyres F 205/40ZR-17
R 205/40ZR-17
Transmission
Gear Type 5 Speed Manual
Final Drive 3.72:1
1st Gear Ratio 3.27:1
2nd Gear Ratio 1.92:1
3rd Gear Ratio 1.34:1
4th Gear Ratio 1.03:1
5th Gear Ratio 0.82:1
Performance
Top Speed 203.0 kph / 126.1 mph
0 - 62 mph 8.2 seconds
0 - 100 mph Not Available
0 - ¼ mile Not Available
EPA City / Highway Not Available
http://www.supercarsite.net/a_210_evolution.htm
Dirty Pusherman 27-08-06 02:37
Re: A 210 Evolution (by AMG)
inca un link...:D
http://www.ultimatecarpage.com/frame...hp&carnum=1315
Dirty Pusherman 30-08-06 19:14
Nici o parere nimic? Sfaturi...ce sa mai modific la ea... :cry: :cry:
sil4tuning 07-09-06 06:25
motorul !!!!
Dirty Pusherman 07-09-06 17:51
ok...alte pareri? :D
Cabbano 07-09-06 19:59
vrei o parere?:-)
e misto masina dar cam mica pt mine:D
alex_starGOD 07-09-06 23:27
Nice rau masinutza man. S-o stapaniti sanatosi! Si sper sa treaca timpul mai repede pt tine...sa poti lua permisul...si sa te poti bucura din plin de ea! Bafta ;)
Dirty Pusherman 08-09-06 01:16
Mersi! :D :D :D
Dirty Pusherman 08-09-06 01:18
Originally Posted by Cabbano (Post 546850)
vrei o parere?:-)
crede-ma pe cuvant ca e aproape mai incapatoare ca ML-ul sau G-ul unei rude!!! (fara porbagaj...doar interiorul)
si e varianta long...
mai bagati pareri & sfaturi!!! :D
MeHiGH 04-10-06 10:58
Ooo!!! Salut Daniel !!!
Am vazut masinutza pe viu ... marfa rau frate...
Daca tot e a ta ... nu te lasa si fa'i ceva cu motoru ...
Ea ... nu e mica deloc ... baga'i niste cai , pe un motor nou ... si ... nimic mai mult ...
BAFTA!!!
gees 27-01-07 19:06
aceasi dimensiune am si eu la jentile 16" si gume Continental PremiumContact si nu cred ca se merita sa schimbi ceva la aceasta masina doar ceva DVD si monitoare sa pui pe ea
Dirty Pusherman 27-01-07 19:14
nush ce femei si-ar lua varianta long...AMG...;) ...in fine...eu va respect opinia...
Dirty Pusherman 27-01-07 19:26
10 Attachment(s)
niste poze mai artistice (blurry) facute din masina... :D
T@zMania 01-02-07 22:31
Originally Posted by PANDA1984 (Post 718159)
are dreptate aici!e cam de femei masina asta dar dak tie iti place spor la modificari!punei folie iar schimba mult aspectul!;)
cam de femeie masina zici....hmmm....dupa nik se pare ca ai panda.....aia ce fel de masina e?
Dirty Pusherman 01-02-07 23:03
Daca ar fi dupa multi...masinile compact ar fi toate de femei...:D
Eu n-am "crezut" niciodata in vorba asta..."aia e de dama, iar aia e barbateasca"...si nu doar la masini!
