VTEC NEEDS MORE THAN JUST RPM'S TO ACTIVATE!!!
These are the requirements VTEC.
1. The engine must be at it's target RPM. (And they're NOT all the same.)
2. The VTEC pressure switch must detect sufficient oil pressure.
3. The TPS sensor must detect sufficient throttle to warrant VTEC.
4. The VSS sensor must detect the vehicle is in motion.
5. The MAP sensor must detect sufficient pressure to warrant VTEC.
6. The Temp sensor must detect the engine is at normal operating temp.
este adevarat tot ce e scris mai sus?trebuie sa le iau pe fiecare in parte sa le verific?cum as putea sa verific senzorul MAP,TPS ai temp sensor?
