Go Back   Forum 4Tuning > Masini & Tuning > MASINA MEA > RENAULT > Masina mea Renault
Old 22-03-13, 13:04   #1
npeti
npeti's Avatar
Default RENAULT CLIO 16V RALLY TIMISOARA
SA VA PREZINT SI EU JUCARIA MEA RECENT INAUGURATA.... UN CLIO 1 16V CU MOTOR 1.8 16V (F7P) PREGATITA PT COMPETITII.
MASIAN AM LUAT-O INTR-O STARE DESTUL DE DEPLORABILA.CU MOTORUL IN PIONEZE. ( LINA SI O BIELA STRICATA) SI BLOCUL CRAPAT. ACU UN AN SI JUMATATE.... DUPA CEVA LUCRU SI BANI INVESTIT IN EA ..MOMENTAN ARATA ASA...
ID:	2726055   Click image for larger version
ID:	2726056   Click image for larger version
ID:	2726058   Click image for larger version
ID:	2726059   Click image for larger version
ID:	2726061   Click image for larger version
ID:	2726062   Click image for larger version
Mitsu 3000 GT TWIN TURBO 3000 V6 24 v dohc
Dacia 1300 2.0 turbo tractiune 4x4
VW Transporter T3 2000 2 carb boxer
CLIO 1 1.8 16v RALLY
fiat 600d (in reconditionare ) 1965
RENAULT 5 GTT
laguna 2.2dci grand tour (pt familie) 2002
npeti is offline   Reply With Quote
Old 22-03-13, 13:20   #2
npeti
npeti's Avatar
Default Re: RENAULT CLIO 16V RALLY TIMISOARA
Dupa o perioada inc are am desfacut masina bucati si am vazut cam ce am nevoie, o urmat o perioada in care am adunat piesa cu piesa necesarele. am scos tot interiorul ..s-o construit roll cageul. inclusiv o traversa prin bord. am modificat aeroterma.si toata tubulatura de aer de prin bord. mi-am fauct niste suporti de scaune din placaj de duraluminu. taiate la jet de apa si indoite la presa hidraulica. concuctele de benzina si cele de frana le-am trecut prin interiorul masini din cupru ambele. am schimbat suspensiile cu kw reglabile pe inaltime.(cand oi avea finante o sa trec la ceva si mai serios.) am pus pe langa frana de mana clasica pe cablu, o fana de mana hidraulica langa schimbator. am cumparat 2 scaune sparco.am curatat-o , am vopsit-o . la motor am luat alt bloc. alt arbore. si 4 biele. am hornuit blocul si i-am facut si planul. am dus schiuloasa la planat si comprimat. are acuma o compresie de 13 bar si. porneste doar cu electromotor de megan diesel de 1.9 cu reductor. la cald.am mutat bateria in spatele copilotului. un contact general pe ea . niste centuri ......si e functionala. in timp am de gand 2 axe mai destepte pentru ea . un soft.si niste blocanti in cutie. Asta asa cu un rezumat sumar.
Old 22-03-13, 18:53   #3
911lau
911lau's Avatar
Foarte frumos e una din masinile mele preferate si ai adoptat un stil care personal il indragesc ....M-a abonez la thred
Succes !
911lau is offline   Reply With Quote
Old 24-03-13, 13:04   #4
badea_laurentiu88
Renault Driver
badea_laurentiu88's Avatar
foarte frumos ce ai facut cu aceasta masina. respectele mele, bafta cu ea mai departe!
badea_laurentiu88 is offline   Reply With Quote
Old 24-03-13, 18:01   #5
PH 96 K R S
PH 96 K R S's Avatar
pfoaa...ce bine arata
PH 96 K R S is offline   Reply With Quote
Old 01-04-13, 19:55   #6
npeti
npeti's Avatar
urmatoarea etapa ar fi o cutie cu lsd..
Old 01-04-13, 23:02   #7
miliady
Renault Driver
miliady's Avatar
frumos bus-ul
si racheta aia mica
miliady is offline   Reply With Quote
Old 02-04-13, 12:23   #8
npeti
npeti's Avatar
merci de aprecieri. la toti.
Old 09-04-13, 17:00   #9
sequention_cielo
sequention_cielo's Avatar
Admir masina, defapt masinile minim de 2 ori pe saptamana(trec la tine in zona), sunt frumoase toate
sequention_cielo is offline   Reply With Quote
Old 15-12-13, 14:12   #10
npeti
npeti's Avatar
Salutare . Masina o primit o alta cutie de viteze cu diferential blocabil quaife . care la randul ei obliga la o modificare a planetarei scurte. acuma se poate umbla la cutie fara sa pierzi uleiul daca dai jos planetarele. Ar urma ceva marire de performante la motor.. caut axe cu came si o electronica pt ea.
Old 15-12-13, 14:20   #11
npeti
npeti's Avatar
si niste poze de asta toamna cu ea. in actiune la vtm.
ID:	2908588   Click image for larger version
ID:	2908589   Click image for larger version
ID:	2908591   Click image for larger version
ID:	2908592   Click image for larger version
ID:	2908594   Click image for larger version
Old 15-12-13, 14:45   #12
Vioar
Foarte frumoasa.
Stii cumva un motor 1,4 turbo de vanzare pe undeva?
Vioar is offline   Reply With Quote
Old 15-12-13, 15:30   #13
npeti
npeti's Avatar
Originally Posted by Vioar View Post
Foarte frumoasa.
nu cunosc. sorry. posibil ca in viitor sa renunt eu la motorul meu ca am mai luat un volvo 460 cu 1.7 turbo.. dar poate doar prin primavara.
Old 15-12-13, 18:09   #14
911lau
911lau's Avatar
Sa faci clio-ul 1.7 sau 5-ul ?
Old 15-12-13, 19:10   #15
npeti
npeti's Avatar
clar 5 ul... Clio va ramane cu f7p. (am si o galerie de evacuare pt f7p pt turbo dar cred ca va fi mai fiabil pe aspirat). 1.7t probabil o sa il pun pe r5,insa mi-e frica sa nu devina subviratorie fiind motorul mai greu.
