Old 17-01-08, 16:11   #1
Default Cabriolet 911 bazat pe Porsche 997 Turbo
Tunerii de la "speedART" ne incanta cu acest Porsche 911, cu sasiu de 997 Turbo. Masina are 600 CP/cuplu 800 nm, motorul fiind unul VTG-Turbo-charger. Sistemul de evacuare e dotat cu sound switch si catalizator sport.
Kitul exterior aerodinamic BTR-XL include bara fata, grila din carbon pentru o mai buna racire si aerodinamica, pragurile laterale, diffusor-ul spate, bara spate ajustabila si oglinzi imbracate in carbon, vopsite in rosu, culoarea reprezentativa a speedART-ului.
Suspensia este una ajustabila sport, cu 6 pistoane 380X32 fata si 4 pistoane 380X28 mm spate. La interior, sunt inserate diferite elemente din carbon, un volan sport speedART dotat cu airbag, short shifter si carpete speedART.
Bolidul poate fi "incaltat" in doua tipuri de jante: RSC II Elegance de 20", vopsite in negru sau Cross Racing de 20", vopsite in alb. In ambele cazuri, cauciucurile raman de 245/30 ZR20 pe fata si 325/25 ZR20 pe spate.
Ca performante, masina nu dezamageste deloc. 0-100 km/h in 3,4 s. 0-200 km/h in 10,8 s. Viteza maxima: 325 km/h (fara cutia de viteze modificata).
Name:	2008-speedART-BTR-XL-600-Cabriolet-based-on-Porsche-911-Turbo-Brake-1600x1200.jpg
ID:	428365   Click image for larger version
Name:	2008-speedART-BTR-XL-600-Cabriolet-based-on-Porsche-911-Turbo-Front-Wheel-1600x1200.jpg
ID:	428366   Click image for larger version
Name:	2008-speedART-BTR-XL-600-Cabriolet-based-on-Porsche-911-Turbo-Oil-Pressure-Gauge-1600x1200.jpg
Name:	2008-speedART-BTR-XL-600-Cabriolet-based-on-Porsche-911-Turbo-Rear-Angle-Top-1600x1200.jpg
ID:	428368   Click image for larger version
Name:	2008-speedART-BTR-XL-600-Cabriolet-based-on-Porsche-911-Turbo-Rear-Angle-1600x1200.jpg
ID:	428369   Click image for larger version
Name:	2008-speedART-BTR-XL-600-Cabriolet-based-on-Porsche-911-Turbo-Side-Angle-1600x1200.jpg
ID:	428371   Click image for larger version
Name:	2008-speedART-BTR-XL-600-Cabriolet-based-on-Porsche-911-Turbo-Side-View-Mirror-1600x1200.jpg
Old 17-01-08, 16:25   #2
2fast4you
Hyundai Driver
[Hyundai]
Default Re: Cabriolet 911 bazat pe Porsche 997 Turbo
Asta e bun de dat zapada iarna la ce garda are. dar nu prea inteleg de au facut oglinzile rosii, ce aia fibra de carbon vopsita? sau imitatie
Old 17-01-08, 16:43   #3
Coss_min
Coss_min's Avatar
Dar tu cam ce garda ai vrea sa aiba un 911? Un 25 de cm cred ca ar fi ok. Oricum masina e super si performantele deasemenea
Coss_min is offline   Reply With Quote
Old 17-01-08, 17:08   #4
Big_85
Big_85's Avatar
mai mult ca sigur nu ar pune imitatie de carbon pe asa masina...e prea de fitze ca sa o strice cu prostii si mai ales cati bani sunt bagati in motor si aerodinamik ar fi pacat sa greseasca in halul asta....rosu ala e cam naspa ca nu e in tema,mai bine nu le mai vopsea,in rest...soooooooper
Old 17-01-08, 17:35   #5
super tare...as vrea sa vad o liniuta intre porsche-le asta si R8 V12 TDI sau si R8-ul ala pe benzina.... . aa?? ce ziceti?? eu unu as baga pe porsche
Old 17-01-08, 17:41   #6
attila
attila's Avatar
nu stiu care ar fi ala care sa bage pe R8
attila is offline   Reply With Quote
Old 17-01-08, 18:26   #7
arata chiar ciudat cu oglinzile rosii dar nu ma supar deloc daca mi-o dau si asa
Old 17-01-08, 18:29   #8
TheMagicPenguin
TheMagicPenguin's Avatar
Thumbs up Re: Cabriolet 911 bazat pe Porsche 997 Turbo
dar tu crezi ca daca au pus fibra, au pus-o pentru fitze?!
Scrie destul de clar: "oglinzi imbracate in carbon, vopsite in rosu, culoarea reprezentativa a speedART-ului"
Masina este o adevarata bijuterie...
TheMagicPenguin is offline   Reply With Quote
Old 17-01-08, 18:32   #9
e o solutie foarte buna de design ideea cu oglinzile rosii... parerea mea e ca arata foarte bine
Old 17-01-08, 20:57   #10
_anaconda_
_anaconda_'s Avatar
cu sau fara oglinzi rosii masina asta e reusita din toate punctele de vedere
Old 17-01-08, 22:38   #11
superb rau
Old 18-01-08, 02:52   #12
Big_85
Big_85's Avatar
nu am zis ca au pus-o pt fitze am zis ca 'e prea de fitze masina ca sa o strice cu prostii' adik s-au bagat bani multi in masina ca sa o strice cu imitatii de carbon si asta o spuneam referitor la msj-ul dinaintea mea da vad ca u citesti doar ce vrea poola ta . oricum rosu ala nu-mi place de nici o culoare chiar daca e culoarea reprezentativa a speedART-ului masina-i alba cu int. negru...
Old 24-01-08, 00:55   #13
rekin
rekin's Avatar
[Colectionar Machete]
Pacat ca nu e coupe!
suuuper oglinzile din carbon!!!!!!
rekin is offline   Reply With Quote
