BMW M5 vs Alpina B5 vs Mercedes-Benz E55 AMG vs Brabus E V12
https://www.youtube.com/watch?v=ZQeOy...elated&search=
M5 Type: V10 Displacement cu in (cc): 301 (4941) Power bhp (kW) at RPM: 500(373) / 7750 Torque lb-ft (Nm) at RPM: 383(520) / 6100 Redline at RPM: 8250 Brakes & Tires Brakes F/R: ABS, vented disc/vented disc Tires F-R: 255/40 ZR19 - 285/35 ZR19 Driveline: Rear Wheel Drive Exterior Dimensions & Weight Length × Width × Height in: 191.1 × 72.7 × 75.8 Weight lb (kg): 4012 (1821) Performance Acceleration 0-62 mph s: 4.5 Top Speed mph (km/h): 155 (250) - electronically limited Fuel Economy EPA city/highway mpg (l/100 km): 12/18 (n.a.) Base Price: 2007 BMW M5 - $82,500 / 86,200 € (last update: 2/20/2007) ALPINA B5 Type: V10 Displacement cu in (cc): 301 (4941) Power bhp (kW) at RPM: 500(373) / 7750 Torque lb-ft (Nm) at RPM: 383(520) / 6100 Redline at RPM: 8250 Brakes & Tires Brakes F/R: ABS, vented disc/vented disc Tires F-R: 255/40 ZR19 - 285/35 ZR19 Driveline: Rear Wheel Drive Exterior Dimensions & Weight Length × Width × Height in: 191.1 × 72.7 × 75.8 Weight lb (kg): 4012 (1821) Performance Acceleration 0-62 mph s: 4.5 Top Speed mph (km/h): 155 (250) - electronically limited Fuel Economy EPA city/highway mpg (l/100 km): 12/18 (n.a.) Base Price: 2007 BMW M5 - $82,500 / 86,200 € (last update: 2/20/2007) MERCEDES-BENZ E55 AMG Standard Engine6.2L V8Standard Transmission7 Speed AutomaticCylinders8********** @ RPM507@6800Fuel Economy Cty/Hwy14 / 20Combined Fuel Economy16EPA ClassMid-SizeNumber of Valves32Torque @ RPM465@5200 (foot-lbs)Fuel Type/SystemGas Engine / Sequential Electronic Fuel InjectedTurbo (yes/no)NoOverdrive TransmissionYesBattery OutputN/ACompression11.3Displacement6208 / 379Bore X Stroke4.02x3.72Cruising Range337.6Final Drive Gear Ratio OptN/APower To Weight Ratio8.3Final Drive Ratio2.82Valves ConfigurationDual Overhead Cam/Twin Overhead CamSuperchargedNoElectric ********** RPMN/AElectric Torque Feet Per PoundN/A (foot-lbs)Electric Torque RPMN/A (foot-lbs)Electric ********** BHPN/A Brabus E V12 Engine Type: V12, Biturbo Displacement cu in (cc): 384 (6300) Power bhp (kW) at RPM: 640(471) / 5100 Torque lb-ft (Nm) at RPM: 757(1026) / 1750 Redline at RPM: n.a. Brakes & Tires Brakes F/R: ABS, vented disc/vented disc Tires F-R: 255/35 ZR19 - 285/30 ZR19 Driveline: Rear Wheel Drive Exterior Dimensions & Weight Length × Width × Height in: 187.9 × 71.1 × n.a. Weight lb (kg): n.a. Performance Acceleration 0-62 mph s: 4.5 Top Speed mph (km/h): 217.6 (350.2) Fuel Economy EPA city/highway mpg (l/100 km): n.a. Base Price: 2005 Mercedes-Benz Brabus E V12 Biturbo - $355,000 / 298,000 € (last update: 2/20/2007) |
Re: BMW M5 vs Alpina B5 vs Mercedes-Benz E55 AMG vs Brabus E V12
votaez brabus E V12 mi se pare ca arata cel mai bine si este si cea mai rapida.
brabusul nu este depasit de nimeni>inca!
vot brabus E! |
brabus E e cea mai performanta, cea mai brutala, dar si cea mai sumpa :)
m5 vs b5 >casiga b5
b5 vs brabus E > brabus E e55 amg vs brabus E > castiga brabus E brabusul ajuta mercedesul sa fie mereu deasupra bmw! daca nu era brabus-ul ar fii ramas mercedes>pt lux si bmw> pt vit. de aia sunt asa de puntine brabus, pt ca sunt f scumpe. |
brabus-ul nu este depasit inca si cred ca nu va fii depasit!
sunt mereu cu un pas inainte. cls-rocket...ultima "inventie" scoasa de cei de la brabus. |
sincer cred ca Brabus E V12 nu prea are ce cauta in vs asta.
face parte din alta clasa de putere si in special in cu totul alta clasa de pret. decat un Brabus E V12 mai bine un m5 si un e55 amg si restul de bani benzina.:)) |
Daca alegi strict dupa date Brabus, e castigator detasat. Dar realitatea poate fi alta.
Uite aici un mic clip , un M6 stock (acelasi motor ca si M5 doar cateva kg bune in plus) si un Kleeman K4 , tot 640 de cai. http://videos.streetfire.net/search/...9b00fcca49.htm Comentariul oficial de la Kleeman: The race between the E55 and the M6 is the result of: 5 speed auto box vs. - 7 speed F1-gear box = ·more opportunities to stay in peak power rev range ·much faster up-shift times The superfast gear shift and many gears give the M6 its major advantage. We also saw how the M-cars were able to give the Gallardo and 997 Turbo with manual shift a run for their money. Other possible factors: ·Vehicle mass (1650 vs 1750 kg)(at least at lower speeds) ·8,000 rpm redline vs 6300 rpm redline |
Eu as alege doar M5! Ganditiva pe circuit daca restul masinilor din versus ii fac fatza! eu cred ca nu! Si mai e si aspectul pret ce inclina balanta tot spre M5
pana aflam dak va face fata ,,noului E63 amg'' M5 ramane bo$$-ul
parerile sunt impartite ce s a zic se inclina balanyta rau de tot
AMG-ul e un "daily car" iar M5-ul un "weekend car"...
trebuia facut un pool!
brabus-ul este cel mai performant, exteriorul isi arata agresivitatea fara de egal! |
tot respectul pt bmw...dar motorul biturbo mananca asfaltul si ce mai e pe langa
| All times are GMT +2. The time now is 21:51. |
