Go Back   4TuningRO > Masini & Tuning > VERSUS AUTO
Old 26-04-07, 01:55   #1
OPC-UL
OPC-UL's Avatar
Oras: ATLANTIDA
Default BMW M5 vs Alpina B5 vs Mercedes-Benz E55 AMG vs Brabus E V12
http://www.youtube.com/watch?v=ZQeOy...elated&search=
M5
Type: V10
Displacement cu in (cc): 301 (4941)
Power bhp (kW) at RPM: 500(373) / 7750
Torque lb-ft (Nm) at RPM: 383(520) / 6100
Redline at RPM: 8250
Brakes & Tires
Brakes F/R: ABS, vented disc/vented disc
Tires F-R: 255/40 ZR19 - 285/35 ZR19
Driveline: Rear Wheel Drive
Exterior Dimensions & Weight
Length × Width × Height in: 191.1 × 72.7 × 75.8
Weight lb (kg): 4012 (1821)
Performance
Acceleration 0-62 mph s: 4.5
Top Speed mph (km/h): 155 (250) - electronically limited
Fuel Economy EPA city/highway mpg (l/100 km): 12/18 (n.a.)
Base Price: 2007 BMW M5 - $82,500 / 86,200 € (last update: 2/20/2007)
ALPINA B5
Type: V10
Brakes & Tires
Performance
MERCEDES-BENZ E55 AMG
Standard Engine6.2L V8Standard Transmission7 Speed AutomaticCylinders8********** @ RPM507@6800Fuel Economy Cty/Hwy14 / 20Combined Fuel Economy16EPA ClassMid-SizeNumber of Valves32Torque @ RPM465@5200 (foot-lbs)Fuel Type/SystemGas Engine / Sequential Electronic Fuel InjectedTurbo (yes/no)NoOverdrive TransmissionYesBattery OutputN/ACompression11.3Displacement6208 / 379Bore X Stroke4.02x3.72Cruising Range337.6Final Drive Gear Ratio OptN/APower To Weight Ratio8.3Final Drive Ratio2.82Valves ConfigurationDual Overhead Cam/Twin Overhead CamSuperchargedNoElectric ********** RPMN/AElectric Torque Feet Per PoundN/A (foot-lbs)Electric Torque RPMN/A (foot-lbs)Electric ********** BHPN/A
Brabus E V12
Engine
Type: V12, Biturbo
Displacement cu in (cc): 384 (6300)
Power bhp (kW) at RPM: 640(471) / 5100
Torque lb-ft (Nm) at RPM: 757(1026) / 1750
Redline at RPM: n.a.
Brakes & Tires
Tires F-R: 255/35 ZR19 - 285/30 ZR19
Length × Width × Height in: 187.9 × 71.1 × n.a.
Weight lb (kg): n.a.
Performance
Top Speed mph (km/h): 217.6 (350.2)
Fuel Economy EPA city/highway mpg (l/100 km): n.a.
Base Price: 2005 Mercedes-Benz Brabus E V12 Biturbo - $355,000 / 298,000 € (last update: 2/20/2007)
atat timp cat va exista apa,aerul si fraierul, nu va venii sfarsitul lumii!
OPC-UL is offline   Reply With Quote
Old 26-04-07, 02:05   #2
BAMBAKE
Banned
Oras: TIMISOARA-maine in toata tara!
Default Re: BMW M5 vs Alpina B5 vs Mercedes-Benz E55 AMG vs Brabus E V12
votaez brabus E V12 mi se pare ca arata cel mai bine si este si cea mai rapida.
BAMBAKE is offline   Reply With Quote
Old 27-04-07, 14:21   #3
mph/km/h
Banned
Oras: las vegas
brabusul nu este depasit de nimeni>inca!
vot brabus E!
mph/km/h is offline   Reply With Quote
Old 27-04-07, 18:14   #4
law53
law53's Avatar
Oras: new york
brabus E e cea mai performanta, cea mai brutala, dar si cea mai sumpa
law53 is offline   Reply With Quote
Old 02-05-07, 15:20   #5
TURBOSS
TURBOSS's Avatar
Oras: pipra-tunari
m5 vs b5 >casiga b5
b5 vs brabus E > brabus E
e55 amg vs brabus E > castiga brabus E
brabusul ajuta mercedesul sa fie mereu deasupra bmw!
daca nu era brabus-ul ar fii ramas mercedes>pt lux si bmw> pt vit.
de aia sunt asa de puntine brabus, pt ca sunt f scumpe.
TURBOSS is offline   Reply With Quote
Old 02-05-07, 16:14   #6
unchiulNOS
unchiulNOS's Avatar
Oras: mi s-a impuscat platina de la delcou...
brabus-ul nu este depasit inca si cred ca nu va fii depasit!
sunt mereu cu un pas inainte.
cls-rocket...ultima "inventie" scoasa de cei de la brabus.
unchiulNOS is offline   Reply With Quote
Old 14-05-07, 20:55   #7
crissti_d
crissti_d's Avatar
Oras: tg-jiu
[Mitsubishi]
sincer cred ca Brabus E V12 nu prea are ce cauta in vs asta.
face parte din alta clasa de putere si in special in cu totul alta clasa de pret.
decat un Brabus E V12 mai bine un m5 si un e55 amg si restul de bani benzina.)
crissti_d is offline   Reply With Quote
Old 14-05-07, 21:24   #8
Bogdan_mb
Bogdan_mb's Avatar
Oras: Oradea
Daca alegi strict dupa date Brabus, e castigator detasat. Dar realitatea poate fi alta.
Uite aici un mic clip , un M6 stock (acelasi motor ca si M5 doar cateva kg bune in plus) si un Kleeman K4 , tot 640 de cai.
http://videos.streetfire.net/search/...9b00fcca49.htm
Comentariul oficial de la Kleeman:
The race between the E55 and the M6 is the result of:
5 speed auto box vs. - 7 speed F1-gear box =
·more opportunities to stay in peak power rev range
·much faster up-shift times
The superfast gear shift and many gears give the M6 its major advantage. We also saw how the M-cars were able to give the Gallardo and 997 Turbo with manual shift a run for their money.
Other possible factors:
·Vehicle mass (1650 vs 1750 kg)(at least at lower speeds)
·8,000 rpm redline vs 6300 rpm redline
Bogdan_mb is offline   Reply With Quote
Old 21-05-07, 16:33   #9
RazvanC4
Oras: Bucuresti
Eu as alege doar M5! Ganditiva pe circuit daca restul masinilor din versus ii fac fatza! eu cred ca nu! Si mai e si aspectul pret ce inclina balanta tot spre M5
RazvanC4 is offline   Reply With Quote
Old 21-05-07, 17:55   #10
Bogdan_mb
Bogdan_mb's Avatar
Oras: Oradea
M5 intradevar e peste un E55 pe circuit, dar nu stiu insa cum face fata la noul E 63 AMG
Old 23-05-07, 01:12   #11
Silviu_Mpower
Oras: Bucuresti
pana aflam dak va face fata ,,noului E63 amg'' M5 ramane bo$$-ul
Silviu_Mpower is offline   Reply With Quote
Old 23-05-07, 01:45   #12
FIGHET
FIGHET's Avatar
Oras: Londra
parerile sunt impartite ce s a zic se inclina balanyta rau de tot
FIGHET is offline   Reply With Quote
Old 23-05-07, 01:47   #13
Bogdan_mb
Bogdan_mb's Avatar
Oras: Oradea
AMG-ul e un "daily car" iar M5-ul un "weekend car"...
Old 24-05-07, 16:48   #14
NOScox
NOScox's Avatar
Oras: rm sarat
Thumbs up Re: BMW M5 vs Alpina B5 vs Mercedes-Benz E55 AMG vs Brabus E V12
trebuia facut un pool!
brabus-ul este cel mai performant, exteriorul isi arata agresivitatea fara de egal!
NOScox is offline   Reply With Quote
Old 05-10-07, 23:27   #15
snookye
snookye's Avatar
Oras: iasi
tot respectul pt bmw...dar motorul biturbo mananca asfaltul si ce mai e pe langa
snookye is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
Copyright 2008 4tuning.ro
