Old 16-11-09, 00:38   #1
IF-01-NSL
IF-01-NSL's Avatar
Default E36 - bmw turbo
motor m50b25
pistoane JE PISTON
biele PAUTER
axe turbo
soft Active Autowerke - BMW Performance Tuner
galerie turbo Active Autowerke - BMW Performance Tuner
turbo ???? Active Autowerke - BMW Performance Tuner
ambreiaj Clutch Masters
cutie m3 6 trepte
diff 3.74 Active Autowerke - BMW Performance Tuner
injectoare ???? Active Autowerke - BMW Performance Tuner
regulator benzina Active Autowerke - BMW Performance Tuner
pompa benzina WALBRO 2 buc
debitmetru Active Autowerke - BMW Performance Tuner
intercooler Active Autowerke - BMW Performance Tuner
garnitura chiuloasa PPF Pyramid Rings
ID:	1177749   Click image for larger version
ID:	1177750   Click image for larger version
ID:	1177752   Click image for larger version
ID:	1177753   Click image for larger version
IF-01-NSL is offline   Reply With Quote
Old 16-11-09, 00:41   #2
IF-01-NSL
IF-01-NSL's Avatar
Default Re: bmw turbo
o sa mai pun poze pe masura ce avansam cu proiectu
Old 16-11-09, 05:44   #3
Skillzu
BMW Specialist
Skillzu's Avatar
Default Re: E36 - bmw turbo
Toti cei care stiu despre ce e vorba cred ca au numai cuvinte de lauda!
Old 16-11-09, 09:13   #4
la prima vedere pare un proiect interesant chiar daca sunt cam putine detalii date despre proiect........am sa urmaresc topicul fiindca sunt curios despre ce e vorba.........succes cu proiectul
like my fb page
Old 16-11-09, 10:46   #5
ice_wysss
ice_wysss's Avatar
Jos palaria..iti urez mult succes..o sa urmaresc cu mare atentie acest thread..
ice_wysss is offline   Reply With Quote
Old 16-11-09, 11:18   #6
negoitacata
2 Roti
negoitacata's Avatar
Foarte tare proiectu...am o vaga banuiala despre ce masina este vorba....Bafta
negoitacata is offline   Reply With Quote
Old 16-11-09, 15:49   #7
Marian_nebunu
Marian_nebunu's Avatar
ce pistoane frumoase :X
Marian_nebunu is offline   Reply With Quote
Old 16-11-09, 16:34   #8
dr_pricop
dr_pricop's Avatar
domnule racer ai pus pozele alea sa murim de inima?spor la treaba si o sa iasa jaleeee sper ca de data asta cata sa ma dea si pe mine
BMW
dr_pricop is offline   Reply With Quote
Old 16-11-09, 16:37   #9
jipianu
jipianu's Avatar
spor la treba... interesant proiectul mai asteptam detalii
jipianu is offline   Reply With Quote
Old 16-11-09, 21:24   #10
Cataaa_
Cataaa_'s Avatar
[Nissan]
intradevar un proiect pe care o sa il urmaresc cu mare interes !!! bafta
Cataaa_ is offline   Reply With Quote
Old 16-11-09, 22:54   #11
ClaudyuNSL
ClaudyuNSL's Avatar
inceputul suna bine..... asteptam detalii pentru ca finalul sigur va fi de exceptie.........
ClaudyuNSL is offline   Reply With Quote
Old 16-11-09, 23:17   #12
LAFv8
LAFv8's Avatar
Originally Posted by IF-01-NSL View Post
motor m50b25
pistoane JE PISTON
biele PAUTER
axe turbo
cutie m3 6 trepte
e chiar treaba ionuteesti pus pe rele
LAFv8 is offline   Reply With Quote
Old 17-11-09, 00:37   #13
IF-01-NSL
IF-01-NSL's Avatar
http://www.motorsport-auto.ro/turbocharger.html#
motoru asta nu este pentru masina me a masina mea are un motor care merge foarte bine si cu interne stok
ID:	1179203   Click image for larger version
ID:	1179204   Click image for larger version
Old 17-11-09, 12:27   #14
negoitacata
2 Roti
Motoru va fi pus cumva pe CTL..??????
Old 17-11-09, 16:14   #15
Skillzu
BMW Specialist
Skillzu's Avatar
Nu e prea scurt 3.74 ?
