Go Back   Forum 4Tuning > AUTO COMERCIAL > Bazar CAR AUDIO > Pachete Audio: Statie+Sub, HU+difuzoare, etc
Pachete Audio: Statie+Sub, HU+difuzoare, etc Pachete Audio: Statie+Sub, HU+difuzoare, etc
Old 19-05-10, 12:47   #1
IF62ALI
Default Vand Pachet Auto Statie Paionner Gm5200t Si Subufar Mtx Impecabile Astept Oferte
Caracteristici amplificator:
Amplificator stereo 2 canale
Putere reala RMS 4 Ohmi 2x125W
Putere reala RMS 4 Ohmi in punte 1x380W
Putere reala RMS 2 Ohm 2x190W
Putere maxima 2x250W
Filtru low pass LPF 80 Hz
Dimensiuni 300 x 61 x 336 mm
Greutate 3.9 kg Subwoofer in incinta bass reflex
diametru difuzor: 30 cm
putere RMS: 250W
putere Max: 750W
impedanta: 4 ohmi
raspuns in frecventa : 30Hz - 150Hz
sensibilitate: 92,4dB / 2,83V / 1m
Xmax : 12,0mm
dimensiuni: 37,0 x 50,0x 41,5cm (HxWxD)
PRETI:8 MIL NEGOCIABIL
Nr:0767828438
ID:	1477924   Click image for larger version
ID:	1477925   Click image for larger version
IF62ALI is offline
Old 22-05-10, 16:30   #2
IF62ALI
Default Re: Vand Pachet Auto Statie Paionner Gm5200t Si Subufar Mtx Impecabile Astept Oferte
up!!!
IF62ALI is offline
Old 08-07-10, 14:46   #3
g_ton
am citit anuntul tau , dar merita sa incerc .... te intereseaza un schimb cu gps thunder navigator sigilat , nou cu garantie 24 luni ? uite link ....
http://www.**************/navigatii-gp...gator-202.html
astept raspuns pe pm ! multumesc !
Ce nu te omoara ...te lasa cu sechele !
CUMPAR VOUCHER REMAT !
g_ton is offline
Old 08-07-10, 15:44   #4
IF62ALI
Imi pare raw da leam vandut
IF62ALI is offline
