1. Statie Jensen XA4150 600W
4 Channel Amplifier
600w Peak power
2 ohm Stable (Stereo Operation)
Tri-Mode Operation
Variable High Pass Crossover (40-240Hz)
Variable Low Pass Crossover (40-240Hz)
12dB/Octave Crossover Slope
6dB Fixed Bass Boost @ 45Hz
High Level Inputs
Input Level Control(s)
Pass Through RCA Outputs
Extruded Aluminium Heatsink
Top Mounted Controls
Thermal/Short Circuit Protection
4x75W RMS Power Per Channel @ 4 ohm
4x100W RMS Power Per Channel @ 2 ohm
2x200W RMS Power Bridged @ 4 ohm
2.Sub. 2 Difuzoare unul 3m 600w si unul No name
3.Cabluri Alimentare + Cele care intra in Player.
Aveti Poze sa va faceti o idee ca dimensiuni are cam asa 83cm Latime si 40cm Lungime
Contact: laur3atu//0762633089
Pret: 550ROn Accept Schimburi cu DVD preferabil 2Din.
