Go Back   Forum 4Tuning > AUTO COMERCIAL > Bazar CAR AUDIO > Difuzoare Auto
Difuzoare Auto Difuzoare Auto, Boxe Auto, Audio
Old 14-04-15, 15:38   #301
pilula20
pilula20's Avatar
Default Re: vand diverse componente de sisteme, boxe, difuzoare, subwoofer si tweetere
Ground Zero Iridium GZIW 250X
subwoofer auto
diametru difuzor: 25cm (10")
putere RMS : 250W
impedanta: 4 ohmi
bobina : 50mm
SPL : 86 dB
FS : 30,1 Hz
QTS : 0.44
Xmax : 14 mm
posibilitate instalare fara incinta - Free Air
adancime instalare : 130 mm
Pret : 300 RON
Telefon : 0724 710 809
Produs nou, sigilat , Garantie 12Luni
Nu accept schimburi !
Transport gratuit in Bucuresti in aceeasi zi !
Pret transport in tara prin Fan Courier 25RON!
http://www.audiolab.ro/…/ground-zero...ziw-200x-clo…/
ID:	3090504   Click image for larger version
ID:	3090505   Click image for larger version
VAND Cd Playere , Difuzoare , Amplificatoare , Subwoofere HELIX , BRAX , MICROPRECISION , MAC AUDIO , ALPINE , CLARION , PIONEER, HERTZ , FOCAL , MAGNAT , DB AUDIO ,BLAUPUNKT, KENWOOD , AUDISON
www.audiolab.ro Numar telefon : 0724 710 809
pilula20 is offline   Reply With Quote
Old 14-04-15, 18:38   #302
pilula20
pilula20's Avatar
Subwoofer auto slim 20cm
Helix E 8W DVC2
difuzor subwoofer
diametru : 200 mm (8")
putere RMS : 200 W
putere max : 300 W
impedanta : 2 x 2 ohmi
membrana tip fagure
borne masive placate cu aur
sensibilitate : 85 dB 1W/1m
frecventa de rezonanta : 52 Hz
parametrii optimizati pentru utilizarea in incinte inchise compacte
Qms : 5,6
Qes : 0,83
Qts : 0,73
VAS : 18 litri
excursie liniara con : +/- 6mm
adancime foarte mica de instalare
adancime instalare : 58 mm
Pret : 385 RON
http://www.audiolab.ro/subwoofere…/…...lix-e-8w-dvc2/
ID:	3090533   Click image for larger version
ID:	3090534   Click image for larger version
ID:	3090536   Click image for larger version
ID:	3090537   Click image for larger version
Old 14-04-15, 18:39   #303
pilula20
pilula20's Avatar
Subwoofer auto slim 25cm
Helix E 10W DVC2
difuzor subwoofer
diametru : 250 mm (10")
putere RMS : 300 W
putere max : 450 W
membrana tip fagure
sensibilitate : 88 dB 1W/1m
frecventa de rezonanta : 46 Hz
Qms : 5,3
Qes : 0,64
Qts : 0,57
VAS : 28 litri
excursie liniara con : +/- 5.5 mm
adancime instalare : 80 mm
Pret : 529 RON
http://www.audiolab.ro/…/helix/espri...8w-dvc2-clone/
ID:	3090540   Click image for larger version
ID:	3090541   Click image for larger version
Name:	Esprit E10W DVC2 4-700x700.jpeg
Name:	Esprit E10W DVC2 6-700x700.jpeg
ID:	3090543   Click image for larger version
Old 14-04-15, 18:40   #304
pilula20
pilula20's Avatar
Subwoofer auto slim 30cm
Helix E 12W DVC2
difuzor subwoofer
diametru : 300 mm (12")
putere RMS : 400 W
putere max : 600 W
membrana tip fagure
frecventa de rezonanta : 37 Hz
Qms : 4,3
Qes : 0,55
Qts : 0,49
VAS : 48 litri
adancime instalare : 87 mm
Pret : 615 RON
http://www.audiolab.ro/…/hel…/esprit...0w-dvc2-clone/
ID:	3090545   Click image for larger version
ID:	3090546   Click image for larger version
Old 20-04-15, 15:40   #305
pilula20
pilula20's Avatar
Vand Kit instalare amplificator
350940 Kit cabluri 10mm², Aiv
Kit instalare amplificator auto
Grosime cablu - 10mm²
Cablu de alimentare - roșu - 5,00 m
Suport siguranță AGU ( placat cu nichel ) - Siguranță AGU (40A)
Papuc inelar M8 - placat cu aur
Cablu gri metalic - 1,00 m
Papuc inelar M12 - placat cu aur
Cablu RCA dublu ecranat + remote - 5,00 m
Pret : 100 RON
http://www.audiolab.ro/kit-i…/…/3509...luri-10mm-aiv/
ID:	3091911   Click image for larger version
ID:	3091912   Click image for larger version
Old 20-04-15, 15:41   #306
pilula20
pilula20's Avatar
Vand Amplificator auto 2 canale
Alpine BBX-T600
Amplificator auto cu 2 canale
Clasa A/B
Putere:
2 x 50W in 4 omi (≤1%THD+N)
2 x 70W in 2 omi (≤1%THD+N)
1 x 130W in 4 omi (≤1%THD+N)
Protectie termica
Protectie pentru suprasarcina
Filtru LP 50Hz – 250Hz
Filtru HP 80Hz – 1.2kHz
Bass EQ 45 Hz
Raport semnal/zgomot: 95dB
Sursa alimentare: DC-DC PWM
Tip sursa alimentare: Direct FET Power
Dimensiuni: 250 mm x 52 mm x 240 mm
Greutate: 1.9kg
Pret : 349 RON
http://www.audiolab.ro/amplificatoar...pine-bbx-t600/
ID:	3091914   Click image for larger version
ID:	3091915   Click image for larger version
ID:	3091917   Click image for larger version
Old 20-04-15, 15:42   #307
pilula20
pilula20's Avatar
Vand Subwoofer in incinta tip cilindru bass reflex
Alpine SWT-12S4
subwoofer in incinta bass reflex
diametru woofer: 12" (30 cm)
putere RMS: 300 W
putere maxima: 1000 W
impedanta: 4 Ohmi
Sensibilitate : 92 dB
raspuns in frecventa: 28-200Hz
diametru tub: 324mm x 660mm
Pret : 299 RON
http://www.audiolab.ro/subwoofere-au...pine-swt-12s4/
ID:	3091919   Click image for larger version
ID:	3091920   Click image for larger version
Old 20-04-15, 15:46   #308
pilula20
pilula20's Avatar
Vand Pachet tub 12" ( 30 cm )
Alpine SWT-12S4 + BBX-T600 + 350940
Pachet Alpine SWT-12S4 Subwoofer tub 30cm (12") + BBX-T600 Amplificator auto 2 canale + 350940 kit cabluri Aiv 10mm²
Alpine SWT-12S4
Subwoofer 12" (30cm)
Tip: Bass Reflex
Putere maxima: 1000W
Putere RMS: 300W
Impedanta: 4 Ω
Raspuns in frecventa: 28-200Hz
Dimensiuni: Ø 324 x 660 mm
Alpine BBX-T600
Amplificator pe 2 canale
Tip: Clasa-A/B
Putere maxima: 300W
Pe Canal in 4ohmi (≤1%THD+N): 2 x 50W
Pe Canal in 2ohmi (≤1%THD+N): 2 x 70W
Bridged into 4ohms (≤1%THD+N): 1 x 130W
Raspuns in frecventa: 5 Hz - 50 kHz (+ 0,-3 dB)
Impedanta: 4 sau 2 Ω
Greutate: 1.9 kg
AIV 350940 Kit cabluri
Pret : 649 RON
http://www.audiolab.ro/…/pachet-tub-...-12s4-bbx-t6…/
ID:	3091923   Click image for larger version
ID:	3091924   Click image for larger version
ID:	3091926   Click image for larger version
ID:	3091928   Click image for larger version
ID:	3091932   Click image for larger version
ID:	3091934   Click image for larger version
ID:	3091936   Click image for larger version
ID:	3091937   Click image for larger version
ID:	3091939   Click image for larger version
ID:	3091940   Click image for larger version
Old 05-05-15, 16:14   #309
pilula20
pilula20's Avatar
Recondionare auto
Volkswagen Kombi
Insonorizare (podea , plafon , bord , usi , capota)
3 bulk - uri x Dynamat Xtreme
1 bulk x Stp Hood Solution
Materialul insonorizant ales pentru interior
Dynamat Xtreme Bulk Pack
Dynamat Xtreme este un cauciuc butii subțire, super-lipicios legat de un strat de aliaj de aluminiu. Dynamat Xtreme este cel mai eficient material de control a sunetului disponibil. Dynamat Xtreme este foarte simplu de taiat și instalat.cauciucul butil și aluminiu se vor intinde si contura mai bine decât orice alt produs pe piață, fără rupere. Acesta se va conforma cu ușurință la toate suprafetele interioare, iar cauciucul butii lipicios va adera la o suprafață și va rămână în loc, fără nicio pregatire speciala a suprafetei, precum și fără a lăsa niciun miros sau material scurs.
contine 9 folii Dynamat Xtreme de 18"x 32" (457mm x 812mm) pentru instalare in orice zona in care se doreste atenuarea zgomotelor si a vibratiilor: panouri usi, bord, plafon, portbagaj etc
atenueaza zgomotul produs de masina si vibratiile produse de difuzoare ducand la o calitate superiora a sunetului
folia suplimentara de aluminiu asigura o eficienta mult mai buna fata de Dynamat Original
Pachetul contine 9 folii 457 x 812mm
Greutate pachet 7.7 KG
Pret : 949.00 RON
http://www.audiolab.ro/…/dy…/dynamat...unk-kit-clone/
Materialul insonorizant ales pentru capota
STP Hood Solution
Antifon gri autoadeziv.
Materialul este o combinatie multistrat compusa dintr-un strat de acoperire (folie de poliester metalizat fono-conducator), poliuretan elastic si strat adeziv protejat de folie antiadeziva. Stratul de acoperire actioneaza ca o bariera impotriva uleiului si benzinei. Temperaturile intre care lucreaza sunt -40°C si 100°C . La producerea materialului este utilizata spuma de poliuretan elastica cu o densitate aparenta de 25+5 -3 kg/m3.
Materialul poate fi montat pe suprafete plate sau denivelate cu o curbura mai mica de 100 mm raza de curbare. Daca suprafata este complexa trebuie luata in considerare taietura de la imbinarea componentelor.
Reduce zgomotul motorului
Reflecta si blocheaza zaldura motorului
Protejeaza vopseaua capotei
Foarte usor de instalat (autoadeziv)
Rezistent la apa si ulei
grosime 10 mm
Pachetul contine 2 folii (80 x 140 cm) si acopera 2.24m2
Pret : 479.00 RON
http://www.audiolab.ro/inson…/standa...p-spl08-clone/
Tel : 0724 710 809
Transport gratuit in Bucuresti!
ID:	3095610   Click image for larger version
ID:	3095611   Click image for larger version
ID:	3095613   Click image for larger version
ID:	3095614   Click image for larger version
ID:	3095616   Click image for larger version
ID:	3095617   Click image for larger version
ID:	3095619   Click image for larger version
ID:	3095620   Click image for larger version
Old 05-05-15, 16:18   #310
pilula20
pilula20's Avatar
Inlocuire sistem audio Oem
Bmw X5 E70 2010 by Match Audio
Difuzoarele alese de client au fost
Match MS 42C-BMW.1 ( Pentru usile fata )
Acest model de difuzoare este unul dedicat BMW fiind plug & play.
Se monteaza in locul difuzoarelor originale pe aceleasi prinderi!
sistem de difuzoare pe 2 cai
diametru midbass 10cm
diametru tweeter 25mm
tweetere cu calota din matase si magnet Neodynium
crossovere incluse in pachet
putere nominala - 60W RMS
putere maxima - 120W
raspuns in frecventa 100Hz-25kHz
sensibilitate 90dB/1W/1m
impedanta 4 ohmi
Modele Bmw compatibile :
Bmw Seria 1 E81, E82, E87, E88 (2004 - 2013)
Bmw Seria 3 E90, E91, E92, E93 (2005 - 2013)
Bmw Seria 5 E60, E61 (2003 - 2010)
Bmw X1 E84 2009 -
Bmw X3 E83 (2003 - 2010)
Bmw X5 E70 (2006 - 2013)
Bmw X6 E71 2008 -
Pret : 580.00 RON
http://www.audiolab.ro/difuzoare-…/m...-ms-42c-bmw.1/
Match MS 4X-BMW.1 (Pentru polita spate)
difuzoare coaxiale pe 2 cai
membrana din polipropilena
tweeter de 20mm cu magnet neodynium
raspuns in frecventa : 100 Hz - 25.000 Hz
impedanta 4ohmi
adancime de montaj - 50mm
Bmw X1 E84 2009 -
Bmw X6 E71 2008 -
Pret : 339.00 RON
http://www.audiolab.ro/difuzoare-a…/...h-ms-4x-bmw.1/
Tel : 0724 710 809
ID:	3095623   Click image for larger version
ID:	3095624   Click image for larger version
ID:	3095626   Click image for larger version
ID:	3095627   Click image for larger version
ID:	3095629   Click image for larger version
ID:	3095630   Click image for larger version
ID:	3095632   Click image for larger version
ID:	3095633   Click image for larger version
ID:	3095635   Click image for larger version
ID:	3095636   Click image for larger version
ID:	3095638   Click image for larger version
ID:	3095639   Click image for larger version
Old 05-05-15, 16:19   #311
pilula20
pilula20's Avatar
Material insonorizant auto
Ground Zero GZDM 3700-AB
- nu are nevoie să fie încălzit, temperatura camerei este suficientă
- amortizare buna
- nu absoarbe apa, nu trebuie să fie protejat separat
- dimensiune foaie de 230 × 400 mm
- pachetul contine 40 de folii
- greutate 10 KG
- grosime de 1.7 mm
- acopera o suprafata de 3,7 m²
Pret : 399.00 RON
Tel : 0724 710 809
Produs nou, sigilat
http://www.audiolab.ro/…/ground-z…/g...-gzdm-3700-ab/
ID:	3095641   Click image for larger version
ID:	3095642   Click image for larger version
ID:	3095644   Click image for larger version
ID:	3095645   Click image for larger version
Old 05-05-15, 16:22   #312
pilula20
pilula20's Avatar
Vand sistem de difuzoare pe 2 cai + subwoofer ( dedicate BMW )
Match MS 83-BMW.1
diametru subwoofer 200mm
putere nominala - 100W RMS
putere maxima - 200W
raspuns in frecventa 30Hz-25kHz
impedanta 4 ohmi
Bmw X1 E84 2009 -
Bmw X6 E71 2008 -
Pret : 1300.00 RON
Tel : 0724 710 809
http://www.audiolab.ro/difuzoare-a…/...h-ms-83-bmw.1/
ID:	3095647   Click image for larger version
ID:	3095648   Click image for larger version
ID:	3095650   Click image for larger version
ID:	3095651   Click image for larger version
ID:	3095653   Click image for larger version
ID:	3095654   Click image for larger version
ID:	3095656   Click image for larger version
ID:	3095657   Click image for larger version
ID:	3095659   Click image for larger version
Old 06-05-15, 21:22   #313
pilula20
pilula20's Avatar
Subwoofer auto
Alpine SWR12D2
subwoofer 12" (30cm)
diametru woofer: 30 cm
putere RMS: 1000 W
putere maxima: 3000 W
impedanta: 2 x 2 Ohmi
sensibilitate: 84.7 dB
raspuns in frecventa: 24-200 Hz
adancime instalare: 162 mm
fisa tehnica
Pret : 659 RON
http://www.audiolab.ro/subwoofere-a…...swr12d4-clone/
ID:	3095913   Click image for larger version
ID:	3095914   Click image for larger version
Old 11-05-15, 19:48   #314
pilula20
pilula20's Avatar
Insonorizare portiere + portbagaj
Opel Astra GTC
Materialul insonorizant ales a fost Ground Zero GZDM 3700-AB
-nu are nevoie să fie încălzit, temperatura camerei este suficientă
- amortizare buna
- greutate 10 KG
- grosime de 1.7 mm
- acopera o suprafata de 3,7 m2
Pret : 399.00 RON
Tel : 0724 710 809
ID:	3097104   Click image for larger version
ID:	3097105   Click image for larger version
ID:	3097107   Click image for larger version
ID:	3097108   Click image for larger version
ID:	3097110   Click image for larger version
ID:	3097111   Click image for larger version
ID:	3097113   Click image for larger version
ID:	3097114   Click image for larger version
ID:	3097116   Click image for larger version
ID:	3097117   Click image for larger version
ID:	3097119   Click image for larger version
Old 16-05-15, 23:21   #315
pilula20
pilula20's Avatar
Vand Inele adaptoare
Set 2 inele adaptoare 16,5cm Toyota
Compatibilitate:
Toyota Corolla 01/2002-> difuzoare usi fata
Toyota Avensis 2005-> difuzoare usi fata, difuzoare panou spate
Toyota Auris 2007-> difuzoare usi fata, difuzoare panou spate
Toyota RAV4 2001-2006 - difuzoare usi fata
-Diametru 16,5cm
-Material plastic ABS de inalta caliate
Pret : 65 RON
ID:	3098059   Click image for larger version
ID:	3098060   Click image for larger version
