Go Back   Forum 4Tuning > AUTO COMERCIAL > Bazar AUTO - PIESE, ACCESORII, CONSUMABILE, etc > Dezmembrari si Piese SH
Old 06-08-13, 19:11   #1
dezmembrariconstanta
Default Dezmembrez Opel Astra H 1.7 CDTI si 1.9 CDTI hatchback si caravan 0723364267
Dezmembrez Opel Astra H hatchback si caravan 1.7 CDTI, 1.9 CDTI an fab 2005, 1.7 CDTI 74kw (101cp) tip Z17DTH si 59kw (80cp) tip Z17DTL, 1.9 CDTI 88kw (120cp) tip Z19DT, 1.9 CDTI 110kw (150cp) tip Z19DTH, cutie de viteze 5+1 si 6+1 trepte, ABS, Radio/CD OEM CD30, comenzi volan, A/C, 8 Airbag, senzori parcare, oglinzi si geamuri electrice, jante aliaj cu cauciucuri 195/65 R15 si R17 spalatori faruri, roata de rezerva slim, bare portbagaj,
Tel: 0723364267
Ym : constantadezmembrari@yahoo.com
Piese disponibile : ELEMENTE CAROSERIE(aripa fata, capota motor, capota portbagaj, hayon, bara protectie fata-spate, portiere, trager, armatura bara,lonjeron, stalp, prag, aparatoare noroi; ELEMENTE OPTICE(far, semnalizator,stop, geam portiera, luneta, parbriz, oglinda; ELEMENTE/ANEXEMOTOR(turbosuflanta, alternator, electromotor, compresor clima, pompa servodirectie, injector,pompa injectie, pompa inalta presiune, pompa benzina, electrovalva, galerie admisie/evacuare, chiuloasa, bloc motor, vibrochen, piston, biela, baie ulei, pompa ulei, suport motor; ELEMENTEDIRECTIE/SUSPENSIE/TREN RULARE(arc elicoidal, telescop, caseta directie, pompa servo directie electrica , brat roata, bara stabilizare, fuzeta, port-fuzeta, jug motor,punte spate, bascule; ELEMENTE RACIRE MOTOR/HABITACLU(radiator apa, radiator clima,radiator intercooler, termoflot, electroventilator apa,racitor ulei, electroventilator ac / clima, teava ac, electroventilator habitaclu; ELEMENTE SIGURANTA(airbag sofer, airbag pasager, airbag lateral, calculator airbag, centura siguranta,pretensionare centura, plansa bord, capac airbag; pasager, ELEMENTE TRANSMISIE(cutieviteze, placa ambreaj, disc ambreaj, volanta, rulment presiune, planetara;ELEMENTE FRANARE(etrier frana, disc frana, pompa servo frana, pompa vacuum;ELEMENTE ELECTRICE(calculator motor, instalatie motor, ansamblu stergator parbriz/luneta, panou comanda ac / clima, macara geam, broasca usa, ceas de bord,contact pornire, debitmetru aer;
dezmembrariconstanta is offline   Reply With Quote
Old 06-08-13, 22:43   #2
cosmin_uau
cosmin_uau's Avatar
Default Re: Dezmembrez Opel Astra H 1.7 CDTI si 1.9 CDTI hatchback si caravan 0723364267
spalatoarele de la faruri de pe bara mai sunt
cosmin_uau is offline   Reply With Quote
