Go Back   Forum 4Tuning > Masini & Tuning > MASINA MEA > HONDA - ACURA > Masina mea Honda - Acura
Old 12-12-12, 20:26   #16
sergiu_evo
sergiu_evo's Avatar
[Honda]
Default Re: '96 CIVIC EK4 VTI (B16A2)-Green
pe lista ii suspensia,bucsele toate de poliuretan,discuri+placute,niste slicuri dupa care cutia facuta cred in ungaria
sergiu_evo is offline   Reply With Quote
Old 13-12-12, 00:54   #17
Comandantul Shake
Comandantul Shake's Avatar
just to warn you, those conversion harness's can be a little touchy, i had one on my old 98 coupe with LS/VTEC and sometimes my passengers would push with their foot where the harness was and the car would stutter and sometimes would die while i was driving it. i eventually figured out it was lackluster workmanship on the wire connections, just want you to be careful
are you sponsored by Sparco??
Comandantul Shake is offline   Reply With Quote
Old 13-12-12, 22:58   #18
sergiu_evo
sergiu_evo's Avatar
[Honda]
thanks for information no,sparco is not my sponsor.i don't have sponsor
Old 19-12-12, 18:21   #19
ionut_50
ionut_50's Avatar
[Honda]
succes cu masinutza sergiu!!!nu merita s-o dai pe bani de nimic
ionut_50 is offline   Reply With Quote
Old 19-12-12, 21:33   #20
giany_TM
giany_TM's Avatar
Egal..3000 euro ,clar trebuie un sponsor...
giany_TM is offline   Reply With Quote
Old 20-12-12, 00:12   #21
sergiu_evo
sergiu_evo's Avatar
[Honda]
au ajuns niste piese,am montat suportii(mersi nebunu si milan) am niste vibrati maxime)altcumva se comporta acum si intra blana in viteze.a ajuns si catback-ul cu convertoru de cat si cold air-u,sper zilele astea sa le montez.am facut si itp-u azi totui check,a verificat-o pe vibratoarele alea nu bate nimic
@gyani_tm: m-as incadra usor in 2000 euro dar mai trebuie multe altele pe langa ce am zis,incet incet se fac toate
@ionut_50:mersi,am vrut sa o dau din lipsa de fiscal si vroiam eg,dar mi-au trecut filmele
Name:	2012-12-18 18.16.04.jpg
ID:	2640752   Click image for larger version
Name:	2012-12-17 09.49.43.jpg
ID:	2640753   Click image for larger version
Name:	2012-12-17 19.31.12.jpg
Old 26-12-12, 20:54   #22
sergiu_evo
sergiu_evo's Avatar
[Honda]
a venit mosu cu ceva bunatati axe brian crower stage 2.ce discuri de frana imi recomandati?sa fie bune dar la pret ok.placutele de frana vor fi momo,am auzit ca sunt foarte bune.vand interiorul complet fete de usi,scaune,bancheta,placaj boxe,plastice etc 170 euro neg
Name:	axe1 brian crower stage 2.JPG
ID:	2644633   Click image for larger version
Name:	axe2 brian crower stage 2.JPG
Old 31-12-12, 00:51   #23
fifty_tm
fifty_tm's Avatar
[Honda]
faina treaba evo , sa-l trimiti pe mos craciun ala si pe la mine !!!
fifty_tm is offline   Reply With Quote
Old 01-01-13, 11:15   #24
sergiu_evo
sergiu_evo's Avatar
[Honda]
ms fifty,cred ca il cunosti pe mos,majoritatea il cunoastem.il vezi de fiecare data in oglinda cand te uiti:P
Old 10-01-13, 21:02   #25
ctrnovice
ii bagi si un soft ceva?
ctrnovice is offline   Reply With Quote
Old 10-01-13, 21:26   #26
sergiu_evo
sergiu_evo's Avatar
[Honda]
axele mai dureaza pana le pun,trebuie arcuri,retainere,supape.am soft pe ecu de pe del sol,trebuie sa incerc daca sunt ok harnessurile de conversie de la obd2a la obd1
Old 13-01-13, 19:09   #27
Toyboy
Toyboy's Avatar
[Honda]
eu zic sa lasi supapele la locul lor (OEM), daca pe del sol softul mergea bine acum cu noile schimbari nu o sa se pupe, deci va trebui resoftat .
Toyboy is offline   Reply With Quote
Old 15-01-13, 20:14   #28
marutzu_vti
marutzu_vti's Avatar
[Honda]
LIKE....
marutzu_vti is offline   Reply With Quote
Old 02-02-13, 23:05   #29
sergiu_evo
sergiu_evo's Avatar
[Honda]
axele au alt propietar....saptamana asta sper sa pun motorul de pe del sol(cu ajutorul lui nebunu) intre timp au venit buza fata si spate si grila
Name:	2013-01-23 21.11.22.jpg
ID:	2677749   Click image for larger version
Name:	2013-01-30 13.45.45.jpg
Old 02-03-13, 22:39   #30
sergiu_evo
sergiu_evo's Avatar
[Honda]
intre timp am schimbat discuri+placute(ate tot) fata si spate si reconditionat etrieri(multumesc nebunu si milan) si azi am montat suspensia koni si bratele din aluminiu
Name:	2013-03-02 13.22.51.jpg
ID:	2706911   Click image for larger version
Name:	2013-03-02 17.32.32.jpg
ID:	2706912   Click image for larger version
Name:	2013-03-02 17.51.47.jpg
Name:	2013-03-02 19.00.31.jpg
