Go Back   Forum 4Tuning > Masini & Tuning > MASINA MEA > AUDI > Masina mea Audi
Old 01-10-12, 05:49   #31
Laserboy
Laserboy's Avatar
Default Re: AUDI COUPE QUATTRO typ85
baga niste poze sa vada si ochiu nostru =))
Laserboy is offline   Reply With Quote
Old 01-10-12, 13:34   #32
BN-01-WSO
Audi Driver
BN-01-WSO's Avatar
A ajuns si ECU impreuna cu LCDul, senzorii si instalatia electrica
ID:	2567605   Click image for larger version
BN-01-WSO is offline   Reply With Quote
Old 02-10-12, 22:24   #33
pasbogdan
pasbogdan's Avatar
Ce camion construiesti tu acolo cu Delvac?
pasbogdan is offline   Reply With Quote
Old 03-10-12, 08:56   #34
BN-01-WSO
Audi Driver
BN-01-WSO's Avatar
)) e factura de la lucru
Old 06-10-12, 08:52   #35
BN-01-WSO
Audi Driver
BN-01-WSO's Avatar
Am inceput sa-mi construiesc galeria de evacuare.
Old 06-10-12, 12:10   #36
CoCaine
Audi Driver
CoCaine's Avatar
Daca ai nevoie de ceva piese iti pot da PM cu numarul unui prieten care are un UrQuattro cu AAN, cred ca are vreo 2 motoare ce au fost inainte pe masina.. Da-mi un PM daca te pot ajuta cu ceva. Are si el ECU aftermarket, l-a instalat si programat singur, poate te ajuta si asta cu ceva..
Audi S2
CoCaine is offline   Reply With Quote
Old 06-10-12, 12:12   #37
BN-01-WSO
Audi Driver
BN-01-WSO's Avatar
Sal. Am vb cu Bogdan, am luat interioru ala rosu de la el. tin legatura cu el. Ms
Old 07-10-12, 08:48   #38
Laserboy
Laserboy's Avatar
si ce sa mai lucrat ieri...
ID:	2573049   Click image for larger version
ID:	2573050   Click image for larger version
Old 07-10-12, 21:10   #39
pasbogdan
pasbogdan's Avatar
Ce material folositi?
Galeria e confectionata dupa un model anume?Mi se par cam lungi runerele,si nu au dimensiuni egale..
O sa aveti nevoie de un suport pt turbina fiindca este enorm de departe de chiuloasa.Nu era mai comod de achizitionat o galerie de pe ebay,varianta chineeasca la 100-200 usd?
http://www.ebay.com/itm/Audi-2-2l-20...673dd2&vxp=mtr
Sau o replica rs2?tot cam la aceiasi bani?Spun asta gandind ca nu ati confectionat galeria din inconel si cunoscand fiabilitatea galeriilor chinezesti.
Avantajul uei galerii tubulare ar fi ca se pot confectiona runere egale.Cum de nu ati mers pe aceasta varianta?
Daca pasiunea nu cunoaste limite e de inteles de ce o confectionati voi.Insa financiar si ca si timp pierdut nu merita.Doar daca ati folosit materiale foarte rezistente la temperaturi..
Sa nu credeti ca sunt eu gica-contra.Felicitari pt munca depusa.Turbina o sa fie cu wastegate intern?
1983 audi coupe b2 2.2l 20v turbo quattro proiect
1986 audi coupe b2 2.2l 20v turbo quattro proiect
1985 audi 90 b2,2.2l 20v turbo quattro proiect
1985 suzuki samurai
1993 audi urs4 2.2l 20 v turbo quattro-dezmembez
1994 audi 100 c4 2.6 E 12 v FWD
2003 vw lt 35
1991 audi s2 3b
Old 15-10-12, 10:35   #40
BN-01-WSO
Audi Driver
BN-01-WSO's Avatar
Dupa modelul 034 am incercat sa o fac http://www.034motorsport.com/engine-...der-p-136.html acuma cat de mult mi-a reusit ramande de vazut. Este facuta din teava de inox de 40 si de 2mm in carne. Sunt multi care le fac asa si cu un suport pt turbo e ok. Avand in vedere ca e prima mea galerie facuta is destul de multtumit de rezultat.
De chinezarii nu m-am interesat si nici nu cred ca gasesti de 10V iar in linkul tau e galeria de 20v si nu potriveste nici cu slujbe
La mine cea mai mare problema e spatiul avand in vedere ca am si admisia si evacuarea pe aceeasi parte. Mi-au iesit toate la milimetru. Sper sa nu se miste prea mult motoru ca e bai. I sudez suportii ))
]UNDERSTEER is when you hit the wall with the front of the car, OVERSTEER is when you hit the wall with the rear of the car
HORSEPOWER is how fast you hit the wall, TORQUE is how far you take the wall with you
Old 15-10-12, 10:59   #41
BN-01-WSO
Audi Driver
BN-01-WSO's Avatar
apropo e cu wastegate extern bineinteles
ID:	2581512   Click image for larger version
Old 15-10-12, 23:30   #42
pasbogdan
pasbogdan's Avatar
Sa "polizezi"frumos sudurie in interior.Succes!!!
Old 16-10-12, 10:40   #43
U_TUNING
U_TUNING's Avatar
[A.C.S. Speedline Motorsport]
[Nissan]
Daca se folosea gaz inert la interior....nu mai era nevoie.
U_TUNING is offline   Reply With Quote
Old 16-10-12, 11:10   #44
BN-01-WSO
Audi Driver
BN-01-WSO's Avatar
momentan astea au fost posibilitatile. Oricum o sa o polizez putin pe interior dar nu are f. multe imperfectiuni. A fost destul de ok sudorul. Ms
Old 18-10-12, 00:16   #45
pasbogdan
pasbogdan's Avatar
Fii mai explicit...
