Vand piese noi si sh BMW E46 si altele
Am incercat o grupare a pieselor pentru o mai usoara cautare a lor !
- faruri complete sedan/touring 1998-2001 fara facelift, originale BOSCH, impecabile, Germania, 200 EUR - al 3-lea stop de frana (dritte Bremslicht) sedan/coupe/cabrio, 150 RON - stopuri E46 sedan fara facelift in alb/rosu, originale, toate 4 + socluri, impecabile, 500 RON - stopuri E46 coupe in alb/rosu, originale, toate 4 + socluri, impecabile, 350 RON - stopuri si semnale de E46 sedan, originale (rosu/portocaliu) toate 6, impecabile, 150 RON - compresor clima nou si original BMW 316i/318i facelift, 200 EUR - compresor clima sh original BMW 316i/318i fara facelift + 320d fara facelift, 200 EUR - compresor clima sh original BMW 320d facelift, 200 EUR - compresor clima sh original BMW X5 3.0L benzina si diesel, 200 EUR - klimatrockner / drying container BMW 64 53 8 377 330 nou si original (vezi numar) 300 RON - furtune clima 316i/318i/320d - DME + EWS E46 M43, BMW 1 430 940, 350 EUR - Grundmodul (inchiderea centralizata si altele) varianta Low (cu 2 geamuri electrice), 100 EUR - unitate ASC (toate E46 fara facelift) sh Germania, 1 an garantie, 500 EUR - debitmetru M43(316i si 318i fara facelift) BMW 13 62 1 433 565, nou si original, 600 RON - debitmetru M43(316i si 318i fara facelift) nou, 450 RON - debitmetru N40,N42,N46(316i si 318i facelift) BMW 13 62 1 438 687, nou si original, 600 RON - debitmetru M52,M54 nou de la Hella/Siemens, aceeasi calitate cu cel original BMW 13 62 1 432 356, 600 RON - debitmetru M47, M47N si M57 nou, 450 RON - debitmetru M47N, M57N si altele, nou si original BMW 13 62 7 788 744,numar BOSCH 0 928 400 504, 600 RON - debitmetru E60, E90 benzina nou si original BMW 7 520 519, 600 RON - debitmetru M54 (325i 2003) BMW 1 432 356, sh, 3 luni garantie, 250 RON - debitmetre folosite BMW 1 432 356, originale BMW, Siemens 5WK9 605/608, 250 RON, 3 luni garantie - senzor presiune BMW 13 62 7 551 429 pt. E9x 335i nou si original, 350 RON - toba mijlocie + spate E46, Motor M43, 316i 318i/ci, noi, toba finala e originala, 300 EUR - instalatie completa CLIMATRONIC noua si originala (tot ansamblul care vine montat in bord), 400 EUR - modul climatronic E46, varianta facelift, nou, 150 EUR - senzor AUC 100 RON - intinzator curea alternator/pompa apa M52, M54 nou si original BMW 1 427 252, 250 RON - intinzator curea original BMW 7 512 758 clima, 200 RON - intinzator curea alternator/pompa apa M43 316i 318i nou si original BMW 1 432 104, 250 RON - intinzator curea alternator/pompa apa M43 316i 318i sh Germania BMW 1 432 104, 100 RON - volan in 4 spite E46, impecabil, complet cu airbag, 150 EUR - set butoane geamuri fata impecabile, 150 RON - nuca noua schimbator din piele, neagra, nu e originala, 30 RON - motorase geamuri electrice fata, 30 EUR bucata - boxe E46 facelift HAES, toate 6, 50 EUR - inel glisant volan E46 (cele pe care vin manetele de semnalizare si stergator), 50 RON - maneta stergator parbriz sedan/touring, 30 EUR - maneta cu BC pentru E34 si E38, 100 RON - maneta fara BC pentru E46, 100 RON - ceasuri bord E46 benzina, 100 EUR - consola standard E46 (vine la frana de mana) 50 RON - trimere standard grafit originale, stare impecabila, 250 RON - trimere negru mat originale, stare impecabila, 450 RON - aparatoare vant fata ClimAir Germania sh, 50 RON - senzor ABS fata pt. toate E46 fara facelift nou si original, 250 RON - arcuri fata E46, 200 RON - repair-kit etrier cilindru frana fata, 50 RON - bielete directie E46 (cele interioare, scurte) 40 EUR - bielete antiruliu toate E46 sh Germania, perfecte, 100 RON - caseta de directie cu bielete interioare pt. toate E46, 250 EUR - pompa servodirectie 316i/318i fara facelift, 150 EUR - rulment fata complet cu flansa original, sh Germania, pt. toate E46, 200 RON - fuzeta completa fata stanga/dreapta toate E46, 150 EUR partea - bucsi bascule fata pt. toate E46 fara M3, noi si originale, 100 EUR - set rulmenti originali amortizoare fata sh Germania - 150 RON - arcuri spate E46, 200 RON - 2 telescoape spate noi, originale SACHS, cabrio/coupe/touring, 100 EUR - 2 telescoape + 2 bucsi(de prindere pe sasiu) spate sh Germania, originale SACHS, sedan, 150 RON - jug diferential E46, 100 EUR - lager mijloc cardan, nou si original, pt. toate E46, 50 EUR - 2X cablu frana de mana, 100 RON - brat aluminiu spate stanga E46, 50 EUR - brat tabla spate E46, 30 EUR - senzor ABS spate E46 facelift, 50 EUR - sonda lambda noua, original BMW 7 537 984, 100 EUR - sonda lambda noua, original BMW 7 545 074, 100 EUR - sonda lambda sh, original BMW 1 247 406, pt. 316i/318i fara facelift, 100 RON - ax came apropape nou(are sub 1000 Km, Germania), original BMW 1 436 853, 150 EUR - tacheti hidraulici, BMW 1 433 672, 20 RON/buc. - volanta 316i/318i fara facelift, 100 EUR - chit ambreiaj nou si original pt. 316i/318i, 150 EUR - electromotor E46 nou, 150 EUR - alternator E46, sh si original, 90A, 100 EUR - bobina aprindere E46 316i/318i, 100 EUR - disc ambreiaj N40,42,46 (316i/318i facelift) impecabil, 150 RON - cablu motor COMPLET M43 (316i/318i fara facelift) 50 EUR - garnitura motor M43 metal, BMW 1 743 191, 50 RON - garnitura motor M43 metal, BMW 1 743 719, 90 RON - corp acceleratie M43, 50 EUR - senzor arbore cotit pt. toate E46 fara facelift, nou si original, 200 RON - pompa apa originala sh Germania pt. M43 (316i/318i 1998-2001) 100 RON - pompa apa noua pt. 3er,5er,Z3 in 6 cilindri benzina, HERZOG Germania, 150 RON - vas expansiune BMW 7 787 040, 150 RON - suporturi plastic radiatoare E46, 50 RON - pompa benzina toate E46 originala, folosita - 300 RON - pompa benzina toate E46 originala si noua (Siemens VDO) 450 RON - indicator de nivel dreapta, nou si original, 50 EUR - filtru carbune sh (piesa neagra din spate, langa rezervor) 150 RON - valva BMW 1 705 497 (breather valve), 150 RON - macarale geamuri stanga/dreapta noi si originale, 200 RON bucata - mecanism inchidere portbagaj E46, 150 RON - balamale portbagaj noi si originale, BMW 41 62 7 001 560 si 559, 150 RON - telescoape portbagaj sh originale, 100 RON - suport oglinda exerioara stanga/dreapta - canale aer coupe/cabrio, 30 RON - cheie 17 roata originala BMW (HEYCO), 30 RON - set suruburi siguranta roata, 150 RON Contact: 0721 48 28 53, Dorin :D |
Re: Vand piese noi si sh BMW E46 si altele
up ... ... ...
trimere standard grafit originale, stare impecabila, 250 RON ...o poza cu ele ai? mersi Marius
parbriz ai cumva?
intrebare: un far stanga+semanlizare pt bmw 316i, 2 usi, 1994, daca ai si cat costa?. merci
Sal, doresc sa imi spui niste preturi la doua telescoape unu fata cu arc si unul spate la un BMW 316 model 1996 noi, aaa.... si bucsele cat m-ar costa la el.Mersi mult.
salut maneta cu BC la ce pret o ai?
turbia pt e46,318d cu facelift ai?si e vre diferenta intre cea de 318D cu cea de 320 D?zi-mi si pret pt ambele,ms
nu am turbine, sorry
cotiera de e46 si pdc ?
- Copyright 2025 4Tuning
