Amplif Clarion
Cam cat as putea sa iau pe statia asta?
Clarion APX4014 4/3/2 Channel Power Amplifier Paintable Heat Sink Design Maximum Power Output 400W Continuous Average Power Output 200W (50W x 4 into 4 Ohms 20Hz-20kHz @0.05% THD) Typical 2-Ohm Stereo 90W x 4 @ 0.5% THD Typical 2 Ohm Mono Power 1kHz 190W x 2 @ 0.5% THD Bass Extender Control 0~18dB @ 45Hz Adjustable 55Hz-5.5kHz, 12dB/oct. High/Low Pass Crossover Mixed-Mode Operation Bridgeable 4/3/2 Channel Operation Speaker Level Inputs Double-Sided Glass Epoxy Circuit Board Arata si functioneaza perfect.O am pe masina de vreo 9 luni. |
| All times are GMT +2. The time now is 00:23. |
