2005 Holden Efijy Concept
7 Attachment(s)
Engine
Type: V8, Supercharged Displacement cu in (cc): 364 (5970) Power bhp (kW) at RPM: 645(480) / 6400 Torque lb-ft (Nm) at RPM: 560(775) / 4200 Redline at RPM: n.a. Brakes & Tires Brakes F/R: ABS, vented disc/vented disc Tires F-R: 255/35 ZR20 - 285/30 ZR22 Driveline: n.a. Exterior Dimensions & Weight Length × Width × Height in: 201.3 × 78 × 54 Weight lb (kg): n.a. Performance Acceleration 0-62 mph s: n.a. Top Speed mph (km/h): n.a. Fuel Economy EPA city/highway mpg (l/100 km): n.a. ATENTIE 645 DINTR-UN V8 LA FEL CA SLR !!!!!!!!!!!!!!!!! >>>>>>>>sieste toata din fibra ......barca ...... :!: |
this must be luv :roll:
Wow :shock: Arata incredibil....
775Nm la 4200RPM :shock: Pacat, nu cred ca o vom vedea vreodata pe sosea... |
superba, asa da retro-style concept!
arata senzational...din orice unghi.. :shock: :shock:
mult rpea smechera ...
ozn bijuterie 8)
mult prea tare masina :D
Super super super tare masina!!!
Re: 2005 Holden Efijy Concept
Pacat ca va ramane doar un prototip...
sil4tuning - acesta masina are si cilindree mai mare cu aproape 500cc ... cuplu mai mic ....
date tehnice - SLR Number of cylinders/ arrangement 8/V, 3 valves per cylinder Displacement cc 5439 Bore x stroke mm 97.0 x 92.0 Rated power kW/hp 460/626 at 6500 rpm Rated torque Nm 780 at 3250-5000 rpm Compression ratio 8.8 : 1 Carburetion Microprocessor-controlled petrol injection with Bosch P-Motronic for load detection, supercharging ontopic : imi place combinatzia de retro cu high-tech |
| All times are GMT +2. The time now is 12:41. |
