Scopemeter TPI 440 6 Instruments in 1
1. Auto Ranging 4000 Count True RMS DMM - TPI's 440 has 9 measurement functions and 0.3% basic DC accuracy. True RMS capability allows the user to obtain accurate measurements of non-sinusoidal AC voltage and current waveforms.
2. 1 Mhz Oscilloscope - View industrial power signals with clarity on the scopemeter display. Simple-to-operate oscilloscope function provides a "picture" of voltage or current waveforms making it easy to detect system problems such as harmonics and waveform distortion. 3. Trend Mode - Graph reading over a predetermined time period to check for the presence of undesirable voltage or current variations. 4. Component Test - (Curve Tracer) Check voltage current signatures on capacitors, resistors, and semiconductors. 5. Logic Tests - Indicates TTL and CMOS logic level tranisitions up to 2 Mhz. 6. Frequency Counter - Measure frequency from 1 Hz to 2 MHz and display duty cycle, pulse width, and period. Aparatul este nou in cutie ,cu tipla pe ecran ,manual ,incarcator ,testere .Masoara f bine ,partea mai slaba este osciloscopul ,oricum mult peste HPS10 de ex care se vinde cu 8 mil . Poate fi folosit pe teren ,acumulatorii tin cam vreo 2 ore ,pentru diagnoza auto sau altceva pentru depanare tv este usor depasit ,vezi SVCC doar daca te astepti sa l vezi ,insa de ex semnalul de 15 khz de comanda linii se vede f bine . Nu fac schimburi ,expediez oriunde ,cumparatorul plateste transportul.Am pregatita pentru el o cutie de 10 ori mai mare plina cu airbaguri . Am sa ceva de vanzare ,il gasiti aici : http://www.**********/catalog/6467870...struments.html |
| All times are GMT +2. The time now is 01:52. |
