-   VERSUS AUDIO (https://forum.4tuning.ro/183-versus-audio.html)
-   -   Infinity Ref1200t + JBL GTO 601.1 (https://forum.4tuning.ro/183-versus-audio/8783-infinity-ref1200t-jbl-gto-601-1-a.html)
giepoko 10-10-05 17:19
De o viata vreau sa imi fac un sistem meserias in masina.Acum ca mi-am luat si carnetu sper sa imi duc la bun sfarsit visu.Drept urmare vreau sa imi cumpar un tub de bas Infinity Ref1200t legat la un amp si nu stiu daca isi merita bani...sau platesc doar numele firmei.Ce sfat imi dati?
Infinity Ref1200t:
Subwoofer Type: 300mm
Enclosure Design: Vented Tube
Max Power Handling: 1200 Watts
RMS Power Handling: 300 Watts
Sensitivity: 95dB (1 Watt/1m)
Nominal Impedance: 4 Ohms
Frequency Response (– 10dB): 35-120 Hz
Dimensions: 340 x 700mm
JBL GTO 601.1:
Power Output : 424 Watts RMS x 1 channel at 4 ohms and ≤ 1% THD + N
Signal-to-Noise Ratio : 72dBA (reference 1 watt into 4 ohms)
Power Output : 580 Watts RMS x 1 channel at 2 ohms, 14.4V supply and ≤ 1% THD + N
Dynamic Power : 778 watts at 2 ohms
Effective damping factor : 6.326 at 4 ohms
Frequency Response : 10Hz – 302Hz (–3dB)
Maximum input signal : 5.3V
Maximum sensitivity : 210mV
vpower16v 10-10-05 19:42
firmele sunt bune ,dar nu fa greseala sa ti iei tub de bass!!!!ia l intr o incinta (oricare vrei tu) dar nu tub. mai citeste pe forum si documenteaza te nu te grabii sa cumperi.mai asculta cateva pareri :)
giepoko 10-10-05 21:32
asta am facut toata ziua :lol: Si nu stiu ce sa fac.Oscilez intre un JBL GTO 1200B + amp sau un JBL P1220 BR.Is confuz, poate ma ajutati voi
As vrea sa am un bas controlat, profund la volume rezonabile(nu exagerate)
P.S.Mentionez ca am 2 difuri Delta 12LF poate poate.... :wink:
NILS_BUCURESTI 10-10-05 21:32
Dap... NU Tub ci Incinta (cubica,trapezoidala, etc cum o vrei)!!! Altfel ... combinatia e ok.
Bafta
NILS_BUCURESTI 10-10-05 21:34
Zi cam in ce suma de bani trebuie sa te incadrezi
NILS_BUCURESTI 10-10-05 21:44
Varianta mai ieftina si mai practica :
JBL GTO 1200B (4.700.000)+JBL GTO 301.1 (5.700.000) = 10.400.000
Varianta mai scumpa ,mai complicata dar mai BUNA :
JBL P1220e (7.300.000)+Incinta (cam 2.000.000)+JBL GTO 601.1 (10.000.000) = 19.300.000
De mentionat ca la preturile astea trebuie sa mai adaugi si cablajele+manopera (daca e cazul)+un condensator daca mai sunt bani :P (vreo 3.000.000)
BAFTA ! :peace:
giepoko 10-10-05 21:45
cam 6-7 mil sub iar ampu pana in 9mil.As vrea totusi sa fie de firma.Am mai mai multa incredere.NU pot sa fac modificari majore in porbagaj intrucat masina nu imi apartine.
giepoko 10-10-05 21:49
Suna tentant.Cutia as face-o eu, problema e cu volumul.Crezi ca ma poti ajuta in privinta asta?
NILS_BUCURESTI 10-10-05 21:52
Cam astea doua sunt variantele de la JBL , la Infinity variantele sunt asemanatoare doar ca la un pret cu vreo 15% mai mare.Mai sunt si alte firme precum Hertz , Ground Zero etc care sunt mai putin cunoscute dar au produse foarte bune ...
BAFTA ! :peace:
NILS_BUCURESTI 10-10-05 21:56
Depinde acum si ce fel de incinta vrei...Sealed (compresie) , Bass Reflex (Vented) etc... te pot ajuta si eu dar cel mai bine ar fi sa vorbesti cu Ground Zero (Ionut) , ReLLaXX , Sfigmo , pt ca ei se ocupa cu asa ceva si te pot ajuta . Pt a te hotara ce incinta vrei cauta pe aici pe forum pt ca s a discutat despre fiecare tip de incinta.
giepoko 10-10-05 22:17
Aham.Dar ce crezi ca ar fi mai bine:sa imi fac o incinta sau sa iau una facuta de firma.Ideea e ca nu as vrea sa risc sa imi iau difu si sa nu am o cutie calculata corespunzator.
vpower16v 10-10-05 23:20
dak nu stii cum sa o calculezi, mai bine apelezi la o firma ,pt k altfel risti sa investesti banii aiurea intr o incinta care nu va \"suna\" cum trebuie
NILS_BUCURESTI 10-10-05 23:27
vpower16v : nu te am recomandat si pe tine pt ca tipul e din Mures :wink: :peace:
vpower16v 11-10-05 00:19
ahh...mersi! nu d asta am postat. ideea e ca am mai avut eu prieteni care
credeau k e simplu sa faci o incinta sau (nu k ar fi cazul d fata aici) se ........pe ei pt cateva sute sa le o faca cineva care stie si iesea un...... :oops: si apoi mai dadeau inca $$$ x2 k sa iasa klumea
NILS_BUCURESTI 11-10-05 01:09
:D si eu lucrez la o incinta cum si sper sa nu iasa aiurea :P Nu e vorba ca m as zgarci si nu as vrea sa dau cuiva sa o faca dar avand in vedere ca ma pasioneaza acest domeniu macar ce consider ca pot face sa incerc 8) Bine acum eu i mi fac si Sealed dupa modelul din manualul Kicker dar daca ar fi fost sa i mi fac bass reflex....nu cred ca mai m as fi aventurat :D
Pt a sustine faptul ca nu m am zgarcit mentionez ca pana acum am cheltuit urmatoarele sume pt incinta : Fierastrau pendular Black&Decker (2.000.000)+MDF 18mm coala de Brico (pe comanda) (2.000.000)+5 tuburi de mastic Bisson special pt lemn (140.000x5=700.000)(am pus sa fie :P )+mocheta Audison 380.000(si mai trebuie)+holdsuruburi(150.000)+2 stinghii din nu stiu ce len esenta tare pt intarituri (200.000) =5.430.000 siu sigur o sa mai apara si alte cheltuieli pt ca inca nu e gata :D
Poza atasata prezinta stadiul actual al incintei :P
