Cumpar statie auto.
dupa cum zice si titlul cumpar o statie intre 200 si 250 ron...poate aveti . :-)
Re: Cumpar statie auto.
SPECTRON SP-A2100 Amplifier 2x100 Watt
Pret 277 RON Power AmplifierSP-A2100 Peak Power Output @4 ohms 2 x 100 W Rated Power Output @4 ohms 2 x 60 W RMS Rated Power Output @2 ohms 2 x 98 W RMS Rated Power Output, bridged, @4 ohms 1 x 180 W RMS Damping Factor (4 ohms)> 100 Signal-to-Noise-Ratio (A-Filter)> 90 dB Frequency Response (+ 0 dB/- 1 dB)20 Hz - 30 kHz Channel Separation> 50 dB Dimensions (W x D x H), mm254 x 230 x 47 http://www.spectron.biz/spectron06/e..._sp-a2100.html http://acrnordic.com/bildbank/produc...100_normal.jpg Noua, in cutie, fact, garantie. Livrare imediata si gratuita din stoc. Date de contact: Semeniuc Cristian Telefon : 0742306018 Email : [email protected] Judet: Suceava |
un magnat ultra 2000,vrei?
pret:150 ron putin negociabil id mess:mihai dj_sony |
amplif Xtreme (by Orion) 300w (160 rms) 2 canale,in garantie inca 5 luni,pret: 200 ron usor discutabil.
Producator: Magnat
* amplificator auto stereo 2 canale * putere o 4 ohmi, stereo: 2 x 65W RMS o 4 ohmi, in punte: 1 x 200W RMS o 2 ohmi, stereo: 2 x 100W RMS * raspuns in frecventa: 5 Hz - 50 kHz (-3dB) * bass boost variabil 0 - 12 dB la 45 Hz * filtre low pass si high pass variabile 40 - 300 Hz (12 dB) * S/N ratio > 100 dB * THD < 0,05% pret 180 ron. |
| All times are GMT +2. The time now is 19:35. |
