Vand statie DLS CA22---in cutie !!!!
Vand statie DLS CA22, impecabila, in cutie! Pentru cei care nu cunosc,DLS este cea mai medaliata firma europeana de car hi-fi.
Date tehnice: Number of channels : 2 Nominal power output in 4 ohm (0,1% THD) : 2 x 50 Watt Typical power in 4 ohm (0,1% THD) : 2 x 60 Watt Typical power output in 2 ohm (0,2% THD) : 2 x 100 Watt Typical power output in 4 ohm bridge mode : 200 Watt Frequency range : 10 Hz - 35 kHz S / N-ratio, A-weighted : > 100 dB Damping factor : > 100 Input impedance low level : > 10 kohm Input impedance, high level : 100 ohm Input sensitivity, variable : 0,25 - 5 V High level input with auto start : Yes Low level output : Yes Highpass filter / subsonic variable : 15 - 500 Hz Lowpass filter variable : 50 - 500 Hz Current draw, idle : 0,5 A Fuse value : 25 A Dimensions H x D x B : 67 x 212 x 250 mm Pret: 3.000.000 lei Tel: 0721.555.956 |
| All times are GMT +2. The time now is 16:09. |
