re: Incinte subwoofer /// Inele MDF la comanda
Incinte.
sus .
un up si din partea mea ... ma ajutat la o incinta pt un brutus square si suna f bn... recomand cu incredere !:D
Mersi, mersi :)
sus .
Sal pt un Us Blaster 15`` 1500 rms cu cat faci ?
The US Blaster ‘LOWRIDERS’ are designed for just one purpose: SPL competition! There's only one way to win, you've got to be the biggest and the baddest! The one with the most loudness! The ‘LOWRIDERS’ are without a doubt the roughest, most intense subwoofers ever invented. At 12 or 15 inch and 21 or 22 Kg, with a total of 28⁄35 mm peak-to-peak excursion, they’re die-cast monstrosities of pure ear-blistering aggression. Designed, tested and built to handle an extreme of 5000 Watts of mind-numbing peak power, these ‘LOWRIDER’ subs aren't the cheapest. But the really good stuff never is! Size: 15 inch ( 380 mm ) Power RMS: 1500 WATT Impedance: 2 x 2 Ohms QMS: 3.35 QES: 0.41 QTS: 0.36 Fo: 33.3 Hz Levc: 1.74 mH SPL: 93 dB VAS: 53 L X-Max: 35 mm OD: 395 mm MD: 218 mm BC: 347 mm CMS: 56.6 mmm⁄N MMS: 394 g MMD: 381 g Magnet: 300 Oz Dimensions: 100*100*7,1 cm Weight: 22 Kg Dimensions for Box; * Box Type; Ported * Liters; 57 * Round Shape Port; 4 inch round, 9,3 inch long * Tuning Frequency; 37 Hz * Minimum 18mm MDF din cate spune pe site :) ms |
Putin cam mica incinta recomandata, dar un design mai bun se poate face fara probleme. Ai pretul pe PM.
un id de mesS?
Din nou valabil.
Poze cu o lucrare recenta : https://i52.photobucket.com/albums/g8...D/IMG_7081.jpg https://i52.photobucket.com/albums/g8...IMG_7080-1.jpg |
up si din partea mea !
sus .
Incinte la comanda pentru orice fel difuzor.
Incinte. Bune.
