-   Amplificatoare auto & stuff (https://forum.4tuning.ro/554-amplificatoare-auto-and-stuff.html)
-   -   cumpar amplificator (https://forum.4tuning.ro/554-amplificatoare-auto-and-stuff/81179-cumpar-amplificator.html)
Detman 14-06-08 21:53
cumpar amplificator
cumpar amplificator 100-150 W RMS @ 4 ohmi, sa fie ieftin.
semecristian 15-06-08 01:47
Re: cumpar amplificator
Pot sa iti ofer urmatoarele variante:
A260 - AXTON Diecast Amplifier 2 kanal
Specificatii http://www.axton.de/druck/Print_A260.html
http://acrnordic.com/bildbank/products/a260_normal.jpg
Specifications A260
Music power, stereo @ 4 ohms (W) 2 x 100
Continuous undistorted output, stereo @ 4 ohms (W RMS) 2 x 60
Continuous undistorted output, stereo @ 2 ohms (W RMS) 2 x 95
Continuous undistorted output, bridged @ 4 ohms (W RMS) — 1 x 180
Frequency response (Hz) 5 Hz - 30 kHz
Harmonic distortion (THD) @ 4 ohms (%) 0.1
S/N ratio (dB) > 95
Channel separation (dB) > 55
Damping factor > 100
Dimensions (W x H x D, mm) 210 x 53 x 256
Nou, cutie, factura, garantie.
Livrare gratuita & imediata din stoc.
Pret 370 RON
SPECTRON SP-A2100 Amplifier 2x100 Watt
http://acrnordic.com/bildbank/produc...100_normal.jpg
Peak Power Output @4 ohms2 x 100 W
http://www.spectron.biz/spectron06/bitmaps/pix-grau.gifRated Power Output @4 ohms2 x 60 W RMS
http://www.spectron.biz/spectron06/bitmaps/pix-grau.gifRated Power Output @2 ohms2 x 98 W RMS
http://www.spectron.biz/spectron06/bitmaps/pix-grau.gifRated Power Output, bridged, @4 ohms1 x 180 W RMS
http://www.spectron.biz/spectron06/bitmaps/pix-grau.gifDamping Factor (4 ohms)> 100
http://www.spectron.biz/spectron06/bitmaps/pix-grau.gifSignal-to-Noise-Ratio (A-Filter)> 90 dB
http://www.spectron.biz/spectron06/bitmaps/pix-grau.gifFrequency Response (+ 0 dB/- 1 dB) 20 Hz - 30 kHz
http://www.spectron.biz/spectron06/bitmaps/pix-grau.gifChannel Separation> 50 dB
http://www.spectron.biz/spectron06/bitmaps/pix-grau.gifDimensions (W x D x H), mm254 x 230 x 47
Pret 295 RON
Date de contact:
Telefon : 0742306018
Email : [email protected]
Judet: Suceava
3xp3rt 26-07-08 19:59
un magnat ultra 2000 vrei,si ieftin???
mihai_djsony:D
AudioCarCenter 28-07-08 14:46
Amplificator Ground Zero GZTA 2.150MK² 4 ohm 2 x 100 WRMS / 2 ohm 2 x 150 WRMS, 400 W max; trimode, 2 ohm stable Pret:340 RON
Amplificator Crunch PZi100.2 100W x 2-Ch @ 4-Ohms Pret:300 RON
Amplificator MacAudio MPX 2500 2x 80 W RMS/ 1X 240 W RMS(Impedanta 4 Ohmni),2 x 120 W RMS (Impedanta 2 Ohmni) Pret:265 RON
Amplificator MNC Hurricane 4 ohm 2 x 100W RMS Pret:265 RON
Toate sunt noi cu factura si garantie
Contact:
ym:caraudio_accesorii sau email
claudiu lucian 05-08-08 16:14
amplificator 2 canale blaupunkt gta 260
putere maxima 400W
putere RMS:
2 x 60W (4 ohmi)
1 x 180W (4 ohmi, punte)
2 x 90W (2 ohmi)
raspuns in frecventa: 10Hz - 30KHz
raport semnal/zgomot: >90dBA
nivel semnal intrare: 0,1 - 8V
salabila in 2 ohmi
filtru LPF: 50 - 250Hz (12dB/oct)
filtru HPF: 80Hz (12dB/oct)
bass boost variabil: 0 - 12dB (45Hz)
aspectuasa si poate pt watii pe care ii are
pret 200 ron
0726.33.95.64
so77 31-01-09 00:34
amplif Xtreme (by Orion) 300w (160rms)2 canale,in garantie inca 5 luni, 200 ron usor discutabil...
paulic 02-02-09 20:20
Magnat Tribal X Two
line
line
Producator: Magnat
* amplificator auto stereo 2 canale
* putere
o 4 ohmi, stereo: 2 x 65W RMS
o 4 ohmi, in punte: 1 x 200W RMS
o 2 ohmi, stereo: 2 x 100W RMS
* raspuns in frecventa: 5 Hz - 50 kHz (-3dB)
* bass boost variabil 0 - 12 dB la 45 Hz
* filtre low pass si high pass variabile 40 - 300 Hz (12 dB)
* S/N ratio > 100 dB
* THD < 0,05%
Magnat Tribal X Two
Imaginea este exemplificativa.
line
line
PRET; 180 RON,
Detman 04-02-09 14:29
closed.
