-   Discutii generale moto (https://forum.4tuning.ro/571-discutii-generale-moto.html)
-   -   Honda CBR 1000RR (https://forum.4tuning.ro/571-discutii-generale-moto/6527-honda-cbr-1000rr.html)
SLY 07-07-05 13:54
Honda CBR 1000RR
ENGINE
Engine Type 998cc liquid-cooled inline four-cylinder
Bore and Stroke 75.0mm x 56.5mm
Compression Ratio 11.9:1
Valve Train DOHC; four valves per cylinder
Carburetion Dual Stage Fuel Injection (DSFI)
Ignition Computer-controlled digital transistorized with three-dimensional mapping
DRIVE TRAIN
Transmission Cassette-type, close-ratio six-speed
Final Drive #530 O-ring-sealed chain
CHASSIS / SUSPENSION / BRAKES
Front Suspension 43.0mm inverted HMAS cartridge fork with spring-preload, rebound and compression-damping adjustability; 4.7-inch travel
Rear Suspension HMAS Pro-Link single shock with spring-preload, rebound and compression-damping adjustability; 5.3-inch travel
Front Brakes Dual full-floating 310.0mm discs with four-piston radial-mounted calipers
Rear Brake Single 220.0mm disc with single-piston caliper
Front Tire 120/70ZR-17 radial
Rear Tire 190/50ZR-17 radial
DIMENSIONS
Rake 23.75 degrees
Trail 102.0mm (4.0 inches)
Wheelbase 55.6 inches
Seat Height 32.5 inches
Dry Weight 396 pounds
Fuel Capacity 4.8 gallons, including 1.06-gallon reserve
OTHER
Available Colors Black/Metallic Silver, Red/Black, Titanium/Black, Blue/Orange/White/Red
Model ID CBR1000RR
FACTORY WARRANTY INFORMATION
1 year Transferable, unlimited-mileage limited warranty; extended coverage available with a Honda Protection Plan.
http://powersports.honda.com/images/...0RR_med_03.jpg
