pareri despre US Blaster USB 5052
mentionez ca sunt interesat de el deoarece am un portbagaj fff mic(peugeot 1007) , s au daca puteti recomanda altceva pe la aceiasi bani(500-600RON).
* Putere RMS Sub-Woofer la 4 Ohmi 150 Watt Ch1 & Ch2 * Putere la 4 Ohmi 50 Watt x 2 Ch1 & Ch2 * Putere la 2 Ohmi 80 Watt x 2 * Putere in punte la 4 Ohmi 150 Watt * Frecventa de raspuns 20 Hz~20Khz * Input Sensitivity 150mV~2V * Input Impedance 15K * Signal-To-Noise Ratio >92 dB * Channel separation >50 dB * Crossover Network Subwoofer Filter 50 Hz~150Hz * Bass Boost 0 dB~+18dB * High Pass Filter 50 Hz~300Hz * Fuse Rating 20A x 2 * Size W x H x L 322x322x480mm Multumesc |
| All times are GMT +2. The time now is 23:05. |
