Boston G24 2/1ch amplifier
Features
2-channel car amplifier Q-Tune™ technology combines sophisticated crossover adjustments with Q-Control settings to seamlessly transition rear bass to the front sound stage The GT's DPS™ (Dynamic Power System™) ensures high efficiency and ouput stages, increased power with lower impedance and maximum dynamics and transient response High-current, high-power design 2-ohm mono operation on all models Advanced cooling allows varied mounting positions Variable crossover points for exact integration of speakers and subwoofers Low-profile height 2Ľ"(57mm) allows installation in tight locations Adjustable mounting feet accommodate varied mounting surfaces Optional GT-RSL remote subwoofer level Power RMS: Multi-Ch. Power @ 4-ohm (12.6VDC) 2x120W Multi-Ch. Power @ 2-ohm (12.6VDC) 2x200W Dual-Mono Power @ 4-ohm(12.6VDC) 1x440W Dual-Mono Power @ 2-ohm (12.6VDC) 1x650W Frequency Response (-3dB) 10Hz-95kHz Signal to Noise Ratio (A Weighted) >100dB Height 2-1/4" (57mm) Width 18" (458mm) Depth (w/Mounting Feet) 8-7/8" (225mm) http://www.ryda.com.au/ProductDetail...Show=TechSpecs Puterea este data la 12.6v(motor oprit). La 14.4v(motor pornit), puterea amplificatorului creste cu 20%. pret: 280euro tel.:0722253815, 0744501628, 0788253815 |
Re: Boston G24 2/1ch amplifier
rezervat pana pe 18.11.07
vandut. se poate inchide acest thread.
| All times are GMT +2. The time now is 12:18. |
