am ceva bass de vanzare ;)
woofer Rockford Fosgate p1l-112 pret 200 e neg
amplificator JBL P80.4 pret 200 e neg amplificator BlueTinum bt-v888 pret 100 e sistem 5.1 JBL pret 150 e |
Re: am ceva bass de vanzare ;)
poze cu sistem 5.1 JBL ???
intra pe id max_380 si iti arat pozele
uppp!hai baietzi!!!
Woofer Box Rockford PL1-112 Single 12" Stage-1 Loaded Enclosure Woofer Quantity 1 Woofer Size 12" Woofer Series Punch Stage-1 Woofer Impedance (ea) 4-Ohm Power Handling 150 Watts RMS 300 Watts RMS System Configuration Ported Enclosure Material 5/8" MDF w/ plexi window Speaker Connector 4 AWG Binding Post Dimensions 15.5 x 19.25 x 16 (in) 39.4 x 48.90 x 40.6 (cm) pret 200 euro Amplificator JBL p80.4 Output 4 Ohms: 40W x 4 Output 2 Ohms: 80W x 4 Output 4 Ohms Bridged: 160W x 2 Signal-to-Noise Ratio: >110 Frequency Response ( ± 3 dB ): 10Hz - 50kHz Total Harmonic Distortion: 0.05% Input Sensitivity: 250mV - 4V Variable 12dB electronic crossover allows the P-80.4 to be configured for a variety of applications The four channels of the P-80.4 can also be configured into three channels or even two channels - this allows for increased expansion capabilities and system flexibility "Direct-Connect" allows choice of 4 - 8-gauge power and ground cable Die-cast chassis uses entire amplifier footprint for cooling - and it looks awesome High-output MOSFET power-supply topology doubles power into 2 ohms http://www.jbl.com/car/products/imag...large/P804.jpg http://images.cardomain.com/member_i...08_95_full.jpg http://images.cardomain.com/member_i...08_96_full.jpg pret 200 euro!!! |
upp! oferta valabila!
uuuuppppppppp!!!!
upppppppppppp!
sus cu el!!!!
