-   Consiliere achizitie audio (https://forum.4tuning.ro/395-consiliere-achizitie-audio.html)
-   -   Ce pare aveti despre aceste 2 pachete? (https://forum.4tuning.ro/395-consiliere-achizitie-audio/55003-pare-aveti-2-pachete.html)
georde 21-10-07 14:27
1. Ce Parere aveti despre acesta? MERITA 400ROm
Pachet bass Mac Audio care cuprinde statie, incinta 30cm si kit de instalare
Amplificator Mac Audio MPX 2500
Amplificator stereo 2 canale
Putere reala 4 ohmi RMS 2 x 80W
Putere reala 1 ohm RMS 1 x 240W RMS in punte
Putere reala 2 ohmi RMS 2 x 120W
Raspuns in frecventa 5Hz-50kHz
Filtre Low-pass si High-Pass variabile
Bass-Boost variabil
Dimensiuni 239 x 59 x 226 mm
Tub bass reflex Mac Audio MP TUBE 30
Difuzor 30 cm
Putere reala 240W
Putere Maxima 480W
Impedanta 4 Ohmi
Raspuns in frecventa 20-200Hz
SPL 91dB
Dimensiuni 327 x 495mm
Kit de cabluri Stinger SWK10R
Cablu alimentare 6m rosu 6mm2
Cablu masa 1m negru 6mm2
Cablu RCA
Cablu remote
Soclu siguranta cu siguranta 30 A
Conectori auriti
2. Blaupunkt MK II 1200 Pachet Bass cu kit instalare cadou ! PRET 470RON
Pachet bass: incinta bass compresie, amplificator si cadou un kit de instalare
Incinta trapezoidala compresie cu difuzor 30 cm Blaupunkt GTt 1200
Putere reala RMS 250W
Putere maxima 750
Raspuns in frecventa 35-500Hz
SPL 91dB
Dimensiuni 482x387x378 mm
Amplificator Blaupunkt GTA 2 Special MK2
Putere reala 4 ohmi RMX 2x60W
Putere reala 2 ohmi RMX 2x90W
Putere reala 1 ohmi RMX 180W in punte
Raspuns in frecventa 10-30000 Hz
Filtre Low-pass si High-pass variabile
Stabila 2 ohmi
Bass -Boost
Dimnesiuni150 x 57 x 260 mm
Kit instalare 200W cadou!!!
5 m cablu rosu alimentare
1.5 m cablu gri masa
Suport siguranta 30A
Cablu RCA 5m
Cablu remote 4.5 m
2 m cablu subwoofer
Terminali conectare subwoofer
SpeeDBreaker 24-10-07 18:27
Re: Ce pare aveti despre aceste 2 pachete?
Nu ma dau in vant dupa ele, insa daca vrei sa-ti achizitionezi unul dintre aceste pachete, as opta pentru varianta a 2-a, acum depinde de preferintele fiecaruia.
spgbuc 24-10-07 23:25
Bass-Boost variabil
Difuzor 30 cm
Putere reala 240W
Putere Maxima 480W
Impedanta 4 Ohmi
SPL 91dB
Cablu RCA
Cablu remote
Conectori auriti
Putere maxima 750
SPL 91dB
Stabila 2 ohmi
Bass -Boost
Cablu RCA 5m
Cablu remote 4.5 m
2 m cablu subwoofer
maine as vrea sa achizitionez pachetul nr 1 ce parere aveti se merita sau nu(sunt total analfabet la audio) si as avea nevoie de sfatul vostru.va raman dator
Loop 25-10-07 03:34
Daca nu uitem la pretul primei variante nu cred sa mai existe vreo alternativa.
pilula20 25-10-07 03:46
mergi pe prima varianta eu zic ca e destul de ok pt pretul pe care il are ;)
spgbuc 25-10-07 23:43
astazi am achizitionat pachetul nr 1
( * subwoofer auto 12 inch
* incinta tub
* difuzor de 30 cm
* putere nominala: 240 W RMS
* putere maxima: 480 W
* impedanta: 4 Ohm
* raspuns in frecventa: 20 - 200 Hz
* SPL: 91 dB
* dimensiuni: 327 mm (diametru) / 495 mm (lungime)
Amplificator MPX 2500
* amplificator auto 2 canale
* putere:
o 4 ohmi, stereo: 2 x 80W RMS
o 2 ohmi, stereo: 2 x 120W RMS
o 4 ohmi, in punte: 1 x 240W RMS
* raspuns in frecventa: 5 - 50000 Hz (-3 dB)
* THD < 0,05% (1 kHz)
* SNR > 100 dB
* filtre LP si HP variabile 40-300 Hz
* bass boost variabil 0-12 dB
* dimensiuni: 239 x 59 x 226 mm)
si sunt foarte multumit de el ii recomand pe baietii de la " ******** " care sunt niste adevarati profesionisti
georde 26-10-07 01:44
NU STIU CE SA IAU am mai gasit un pachet?
NU STIU CE SA IAU sunt praf in ale tehnici audio... :?: :sad:
Suma maxima de achizitii(sub. ampli. cabluri) fara condesator 600 ron..
CE ma sfatuiti sa iau:?:
Am magi gasit inca un pachet Acesta este:
Streetracer 3000 XXL
subwoofer auto - tub bassreflex 12"
putere RMS: 300W
putere Max: 1000W
impedanta: 4 ohmi
raspuns in frecventa: 19Hz - 200Hz
SPL: 95dB
SI
Ultra 2000
amplificator 2 canale
putere RMS:
2 x 45W (4 ohmi)
2 x 65W (2 ohmi)
1 x 130W (4 ohmi, punte)
putere Max:
2 x 140W (4 ohmi)
2 x 200W (2 ohmi)
1 x 400W (4 ohmi, punte)
raspuns in frecventa: 5Hz - 50KHz (-3dB)
distorsiuni: <0.05% (1KHz)
raport semnal/zgomot: >100dB
semsibilitate intrare: 0.4 - 4V (pe intrarile RCA)
filtru LPF variabil: 40 - 300Hz
filtru HPF variabil: 40 - 300Hz
Bass Boost: 0 - 12dB
dimensiuni: 240 x 52 x 238mm
greutate: 1.85Kg
LA pretul de 570Ron cu tot cu montaj
spgbuc 26-10-07 12:16
poti sa te duci sa il asculti si sa vezi daca iti place.Asa am facut eu si pe mine m-a costat 6mil(fara condensator pt ca momentan nu am nevoie:D) cu tot cu un adaptor pt cassetofon
