-   VERSUS AUDIO (https://forum.4tuning.ro/183-versus-audio.html)
-   -   rx mono (https://forum.4tuning.ro/183-versus-audio/51738-rx-mono.html)
Detman 16-09-07 12:30
rx mono
magnat rx mono
amplificator auto mono
putere
4 ohmi: 1 x 500W RMS (1 x 1000W max)
2 ohmi: 1 x 700W RMS (1 x 1400W max)
1 ohm: 1 x 1000W RMS (1 x 2000W max)
Raspuns in frecventa 5 - 250 Hz
THD < 0,05 % (1 kHz)
filtru LPF variabil 40-250 Hz, 12 dB
filtru subsonic variabil 10-40 Hz, 12 dB
Bass boost variabil 0-15 dB la 45 Hz
dimensiuni: 450 x 50 x 261 mm
intrari / iesiri RCA aurite
control volum remote (telecomanda pe fir)
vs
magnat Rock Mono 1000
amplificator monobloc pentru subwoofer
putere:
4 ohmi: 350W RMS (750W max)
2 ohmi: 500W RMS (1250W max)
1 ohm: 700W RMS (1800W max)
impedanta suportata: 1-8 ohmi
raspuns in frecventa: 5 Hz - 50 kHz (-3dB)
THD < 0,05% (1kHz)
intrare de linie 0,25V - 4V
filtru low pass variabil 40-300 Hz (12 dB)
filtru subsonic (high pass) 10-40 Hz (12 dB)
bass boost variabil 12dB la 45 Hz
circuit de protectie la supraincalzire si scurtcircuit
mac audio fearless 1000
amplificator 1 canal
putere RMS:
1 x 600W (4 ohmi)
1 x 900W (2 ohmi)
raspuns in frecventa: 5Hz - 75KHz (-3dB)
distorsiuni: 0.03% (1KHz)
raport semnal/zgomot: 100dB
filtru LPF variabil: 40 - 300Hz (12dB/oct)
filtru subsonic variabil: 10 - 80Hz (12dB/oct)
Bass Boost: 0 - 12dB (45Hz)
reglaj faza: 0 - 180º
nivel semnal intrare: 400mV - 4V
tensiune alimentare: 12V (9 - 15V)
dimensiuni: 46 x 6 x 29cm
greutate: 6 Kg
