-   -   Dictionar Termeni (https://forum.4tuning.ro/322-zona-tehnica-vw/47011-dictionar-termeni.html)
CJ-01-WOB 25-07-07 03:19
Dictionar Termeni
Aici puteti gasi explicatiile care nu le cunoasteti , cuvintele care nu le intelegeti ,simbolurile care nu le stiti (VAG - si nu numai )
Gen : Gti , Tdi, Sdi, VR6 , v12, R32, G60 samd !
CJ-01-WOB 25-07-07 03:30
Re: Dictionar Termeni
ABS = Anti-lock brake system
DC = Distance control
ADC = Automatic distance control
EDC = Electronic diesel control
TDI = turbocharger direct injection
DCI = direct commonrail injection
FSI = fuel stratified injection
Gti = Gran Tourismo Injection
ESP = electronic stability program
MPI = multi-point injection
HTP = High Torque Performance
DSG = Direct Shift GearBox
WOT = Wide open throttle
TCS = Traction Control Sistem
PD = Pumpe Duese
OBD = On-Board Diagnostics
CJ-01-WOB 25-07-07 03:36
multa lume m-a intrebat de la ce vine MK
adica ce inseamna vw golf mk1 sau toyota supra mk4
Ce spune WIKIPEDIA :
''The word Mark (MK), followed by number, is a common way to name a product in a production line, similar in meaning to "Type". It is often abbreviated as Mk or M. Because a mark is often made to measure height or progress, by metonymy the word mark is used to mean a level of development, and level designations like "Mark I", "Mark II" etc. come to be used as proper names. However, since the same name is used for a wide variety of products, it can have varied connotations for different persons.
In other words, "Mark" (or Mk.) refers to the development of something, say, a prototype. The first product would be known as Mark 1. Then changes would be made, the second, revised product would be known as Mark 2. If more changes are added, the third product is called Mark 3, and so on, and so forth ''
pe intelesul tuturor termenul MARK vine de la serie, generatie,model,numar
dj_geo_bv 13-09-07 16:31
Te rog poti sa-mi spui si mie cum e cu literele la TDI ? Ca am vazut TDI cu D si I rosu cu 75 cp..al meu tot asa are literele dar 101 CP ...multumesc
Pt polo. 9N1 as vrea sa stiu...:)
claudiu lucian 03-01-08 00:37
depinde de anul de fabricatie! dar acele litere se gasesc si in comert. a un vecin, 90 cp cu D & I rosii(sunt puse de el). Si puterea difera la fiecare generatie, din cate stiu...era "I" rosu cu 90;101;si mai nou cu 119-120cp
claudiu lucian 03-01-08 00:40
modelul de polo..cum e golf 1-2-3etc. 9n1 este prima varianta a acelui model, 9n2-varianta cu facelift ....cu unele modificari aduse acelui model.
sper sa ma fi facut inteles. o sa incerc sa fac ceva constructiv in privinta asta.
the_fury 08-01-08 20:49
Eu vreau sa stiu de la ce vine WOB mai intai:D Multumesc!
CJ-01-WOB 08-01-08 21:50
::lol: clasic
WOB - vine de la WolfsBurg orasul MAMA al Volkswagen
acolo ies ele la lumina :-) . Wolfsburg mai este cunostut ca si Golfsburg dupa ce afost omagiata a 5-a generatie vw golf .
Practic orice vw care iese la lumina are placute cu WOB ( simbolurile orasului )
vw-WOB! - o revista de tuning dedicata VAG in special golfurilor pe piata inca din anii 90 din care am avut placerea sa ma inspir si sa aflu atatea chestii despre Golfuri
Multi din pasionatii marcii au placute de inmatriculare cu WOB indiferent in ce tara se afla ( probabil ai mai vazut masini din alte tari cu WOB la numar )
http://www.wob24.de/html/assets/kopf/logo.jpg
the_fury 09-01-08 13:43
Niciodata nu e prea tarziu sa invat, si da, am vazut foarte multe vw cu numar de wob si de aceea mi-am dat seama ca vine de la ceva... Multumes si scz de off-topic!
vacaroz 10-01-08 09:06
foarte tare thread`ul. o sa`l urmaresc cu placere. buna idee
bmwm5 10-01-08 09:18
mai puneti...
claudiu lucian 10-01-08 11:15
am gasit si eu cateva:
DSC ( controlul dinamic al stabilitatii )
DTC ( controlul dinamic al tractiunii )
CBC ( controlul sistemului de franare in curbe )
DBC ( controlul dinamic al sistemului de franare )
vacaroz 10-01-08 20:11
care e diferenta intre gt si gti de la vag? sau mai exact ce inseama gt.gti scrie mai sus. am vazut si pe golf 3 GT
danxxl 28-03-08 19:05
am vazut ca fiecare descrieti masina,la passat ma refer gen:b1,B5,etc.Am si eu passat si in afara de faptul ca e 1,9 tdi 131cp 2005.Alta denumire nu stiu la el.Cine imi poate spune despre ce e vb?
